Thread: A6 C7 trailer prep issue
Results 1 to 9 of 9
  1. A6 C7 trailer prep issue
    May 2022
    Argyll
    Evening all,
    Iím having an issue fitting a dedicated trailer electric kit to my allroad. I have located the red plug that goes into the loom without issue however the instructions make mention of the CAN 2 pin connectors in the loom that require attaching, so far I have not been able to find these and would be grateful of a pointer. Please see attached image.
  2. Re: A6 C7 trailer prep issue
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    On my C7 avant they where above the wheel arch, further up the loom towards the fuel flap, think the same for my C7.5 Allroad. It'll have a diagram on the westfalia instructions normally.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  3. Re: A6 C7 trailer prep issue
    May 2022
    Argyll
    Many thanks. Found it after some help from the manufacturer, guess I’ll need some cloth tape ��.
  4. Re: A6 C7 trailer prep issue
    May 2022
    Argyll
    Did you have to code yours too Kev?
  5. Re: A6 C7 trailer prep issue
    Feb 2016
    53 Post(s)
    Yeah coded mine on the Allroad myself with OBD11, I did a lot of research to find out which modules to code and what to change, did it via long coding, but that was nearly 4 years ago now so have no idea exactly what I changed. I do know the tailgate now doesn't open fully if something is plugged into the trailer socket unless you use the button on the outside of the tailgate.
    From memory the chassis control was programmed, 5F module, ABS, engine control, module 69 is trailer module. I had a good look on the VCDS forums and a lot of googling. Ill try find my crib sheet of what I changed.
  6. Re: A6 C7 trailer prep issue
    May 2022
    Argyll
    Many thanks. I had VCDS before I moved to Canada, upon my return I appear to have misplaced it, I've just ordered OBDeleven so any pointers would be appreciated.
  7. Re: A6 C7 trailer prep issue
    May 2022
    Argyll
    My OBDeleven has arrived, I’m more familiar with VCDS which I no longer have, any assistance regarding coding, particularly [19] would be appreciated, no lights working on the trailer.
  8. Re: A6 C7 trailer prep issue
    Feb 2016
    53 Post(s)
    morning Heehaw,
    Is your Allroad pre facelift or post facelift?
  9. Re: A6 C7 trailer prep issue
    May 2022
    Argyll
    It’s a pre facelift (2013). I’ve ironed out most of the creases. Trailer lights work, no longer have air suspension fault and car fog light disable, parking sensors and MMI screen behaving as they should, just want to double check I havn’t left anything out.
    Can’t seem to add the trailer option to brakes, only one I know hasn’t been completed. And I can’t log into the trailer module but everything works.
    Many thanks in advance once again.
  1. RS4 Trailer electrics - installation issue
    By wmccann in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-09-2020, 11:55 PM
  2. A6 4F trailer module not accepting trailer with LED lights
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-07-2020, 03:40 PM
  3. Model years, changes on each model year - and when was trailer prep standard
    By Karl in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-07-2012, 01:31 PM
  4. Phone prep low volume issue
    By neilsafc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-07-2010, 07:52 PM
  5. Trailer Turn Signals Not Working - but Trailer not Connected
    By tidybutt in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 07-05-2009, 09:24 PM
