Thread: front suspension rubber top mount
  1. front suspension rubber top mount
    Dec 2020
    capital
    Any one got any pictures of a busted / damaged, or how or what ever renders them to be changed.
  2. Re: front suspension rubber top mount
    79 Post(s)
    1377 Post(s)
    The rubber never fails but the bearings get water in them and rust. We use the Febi 37878 repair kit which gives you all the parts you need except hub nut and ball joint bolts
    Slava Ukraini!
  3. Re: front suspension rubber top mount
    Dec 2020
    capital
    cheers.
  4. Re: front suspension rubber top mount
    Dec 2020
    capital
    hit a pot hole, so i thought it was the culprit for some reason.
    if its not that, anybody have an idea what damage a pot hole would cause quite a thump espacialy over humps with a lip, if its a smooth on smooth off hump then there no thump/thud noise.
  1. modify front suspension mount
    By helmsy157 in forum 80 - 90
    Last Post: 22-01-2016, 05:19 PM
  2. Question Engine Cover Rubber Mount - how do I replace this?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2014, 09:39 PM
  3. Nearside Front Lower Suspension arm rubber bush deteriorated
    By jeepster1961 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-09-2013, 10:07 PM
  4. Front (lower) suspension arm rubber bush
    By susanclark1 in forum Fabia
    Last Post: 02-02-2011, 07:58 AM
  5. Front Suspension Top Mount
    By rich115 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-04-2010, 09:37 PM
