Thread: 2006 2.0tdi Sport BMR - DPF
Results 1 to 9 of 9
  1. 2006 2.0tdi Sport BMR - DPF
    Leicestershire
    8 Post(s)
    Evening all,
    Over the next couple of weeks I’m going to be swapping from a Golf 1.5 tdi that I’ve had from new (now 3 years old) to a 2006 Passat estate.
    My daily commute is 40 miles total with roughly 20 miles being motorway, 15 miles of 50mph A Roads and 5 miles of mixed slower driving with a bit of stop start. How will the Passats DPF handle this kind of journey? Will I know when it’s doing a regen, when the Golf does one it’s quite obvious but I’m unsure about the older technology?
    thanks for any advice / tips
  2. Re: 2006 2.0tdi Sport BMR - DPF
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    You probably won't notice the regeneration at all as my daily commute used to be 2 miles at 30mph, 25 miles at 60mph, 5 miles motorway 70...ish! then finally 3 miles of winding country lanes and through villages. The reverse on the way home.
    Exhaust / DPF temperatures on such a journey would be easily sufficient for passive regeneration as opposed to active regeneration where the car decides it is time to heat things up a bit by dumping extra fuel into the mix. Rarely did I notice anything over the years I had to do that commute. On the other hand when I changed work locations to only 14 miles each way, the active regeneration was a spectacle of clouds of oil smoke for a minute or two, as I need a valve stem seal or two replaced, a pig of a job, have done it once already.
    Mad Mitch
  3. Re: 2006 2.0tdi Sport BMR - DPF
    Leicestershire
    8 Post(s)
    It seems I should be ok then. Thanks 👍🏽
    Just the over filled oil to sort out now.. The RAC said they will tow me to a garage 🙄
  4. Re: 2006 2.0tdi Sport BMR - DPF
    1837 Post(s)
    I would be more worried about the oil pump than the DPF, especially if it is early 2006!
  5. Re: 2006 2.0tdi Sport BMR - DPF
    Jan 2012
    10 Post(s)
    87 Post(s)
    Beating Gazwould to the punch on the oil drive issue, unheard of!
    Mad Mitch
    2 0 0
  6. Re: 2006 2.0tdi Sport BMR - DPF
    Leicestershire
    8 Post(s)
    yep, I’m on it
  7. Re: 2006 2.0tdi Sport BMR - DPF
    1837 Post(s)
    This is the latest revised design we are fitting at the moment
  8. Re: 2006 2.0tdi Sport BMR - DPF
    Jan 2012
    10 Post(s)
    87 Post(s)
    Crasher,
    Any idea what size the shell bearings are inside the balancer unit, mine seem very smooth and worn so I'm hoping to source some new replacements from a bearing supplier?
    I see fully refurbished balancer units online for £342 these days but wanted to keep my rebuild costs down a bit.
    Mad Mitch
  9. Re: 2006 2.0tdi Sport BMR - DPF
    1837 Post(s)
    In the old balancer? No idea as the scrap man threw it in his van yesterday… it had done 180k (and was dated 06/2006, therefore the original) so must have been worn. We will only fit new genuine units with a new crank drive gear so we get the peace of mind of a two year dealer backed warranty. When cleaning the sump yesterday the mechanic Matt commented on how clean the sump was internally, this is because the owner sticks to 9000 mile oil changes and is good evidence to show that the stupid LongLife service regime was more to blame than a silly 6mm hex key. Incidentally the pump end of the key showed absolutely zero wear. Changing the crank spur gear is evil compared to the chain sprocket, it broke the tool! £90 and on back order
  1. Replies: 4
    Last Post: 06-06-2015, 12:57 PM
  2. Question A6 2006 3,0TDI BMK/headlamps
    By bussen in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-09-2014, 11:41 PM
  3. 2006 a4 2.0tdi 140 cutting out?
    By tdigolf in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-12-2012, 04:16 PM
  4. 2006 A6 2.0TDI First Impressions
    By c0l in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-03-2011, 06:13 PM
  5. Question 2006 2.0TDI SPORT Timing belt replacement
    By CNPrior in forum Jetta MK3 - 2005 - 2013
    Last Post: 16-07-2009, 10:51 PM
