Thread: 05 1.9 tdi sharan gearbox question
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. 05 1.9 tdi sharan gearbox question
    May 2010
    edinburgh
    Hi all, advice please. I have just purchased above vehicle..drives well, and in good condition. My only concern is the gearbox, it is slightly noisy..whirry, if thats a word! I had a touring the same age last year sounded similar, and eventually the gearbox gave up completely. Would there be any advantage to changing gearbox oil? Has anyone done this and found it helped! Any advice appreciated, Cheers
  2. Re: 05 1.9 tdi sharan gearbox question
    1836 Post(s)
    Yes those boxes are known for failure, an oil change plus an additive such as Slick 50 won't reduce the noise or prevent failure but won't harm either.
  3. Re: 05 1.9 tdi sharan gearbox question
    May 2010
    edinburgh
    Ok..thank you. I take it its a similar box to touran?! Can you advise on a good gearbox oil to use please? Cheers.
  4. Re: 05 1.9 tdi sharan gearbox question
    1836 Post(s)
    I use RedLine which I think would be their MTLV in that box but there are dozens if not hundreds of excellent brands, it is actually a quite bewildering subject.
  5. Re: 05 1.9 tdi sharan gearbox question
    May 2010
    edinburgh
    Ok. Thanks for the advice, I will investigate further!
  6. Re: 05 1.9 tdi sharan gearbox question
    May 2012
    Everywhere
    308 Post(s)
    Key to this is the cold viscosity this has a massive effect on the quality of shifts , thinner being better determined by the data sheet on any aftermarket oil .
    I recently suggested with fantastic feedback this....
  7. Re: 05 1.9 tdi sharan gearbox question
    May 2010
    edinburgh
    Thanks! How many litres would i need, and where do I get it..Will also add slick 50. Cheers
  8. Re: 05 1.9 tdi sharan gearbox question
    1836 Post(s)
    Opie oil do Red Line, well almost everyone's oil. The capacity is 2.2 litres from memory so you will need three 0.946 litre bottles.
  9. Re: 05 1.9 tdi sharan gearbox question
    May 2010
    edinburgh
    Thank you, have contacted opie oils. I haven't gone under car yet to see what access is like! Is it quite easy to get into? Should I invest in a syringe to get the new oil in! Cheers
  10. Re: 05 1.9 tdi sharan gearbox question
    1836 Post(s)
    The rain could be 17mm AF or XZN 16 or XZN 16 tamper proof and there is no guarantee the fill is the same as the drain. We use a pump, a funnel and hose for you would be easiest.
  1. 02 Sharan Gearbox out this weekend!!
    By bmwdumptruck in forum Touran - Sharan - Caravelle
    Last Post: 16-03-2011, 11:24 PM
  2. fitting a gearbox , sharan 1.8 t
    By jamesey in forum Touran - Sharan - Caravelle
    Last Post: 06-01-2009, 10:42 PM
  3. Question Sharan Or Not Sharan - That is the Question.
    By Briljant in forum Chat - Anything with wheels
    Last Post: 19-09-2008, 10:32 PM
  4. sharan gearbox problem
    By busa1999 in forum Touran - Sharan - Caravelle
    Last Post: 11-01-2006, 08:28 PM
  5. sharan gearbox problem
    By busa1999 in forum Archive posts
    Last Post: 10-12-2005, 10:08 PM
