Thread: Golf MK5 FSI P0576
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    Hello All ,
    I do have a Golf MK5 FSI ,2.0
    No windows working , no electric roof , no AC controls , tried with launch and with autel , no communication with all this control unit : driver door , passenger door .. electric roof etc ....
    Suspected error is
    In 09 Electronics
    P0576 KL15 ....
    Looking to the relay box under the dash left side
    No relay is plugged there on the KL15 !
    Pls advise , ur help is really appreciated
    With kind regards
    Adel
  2. Re: Golf MK5 FSI P0576
    108 Post(s)
    1816 Post(s)
    KL15 is for line 15 so ignition live, without that relay you have no ignition power, why is it missing?
  3. Re: Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    Thank u Crasher ,
    First sorry If i m not putting the whole story of the car :
    1-/ car ECU have a problem : no throttle , ECU have been changed with same part number , engine run fine , just only some times the engine off from itself when u try strat u couldn't hear the fuel pump working , FP changed , FP control unit changed , all fuses controlled , everything looks ok
    Error when the car is off : Nox sensor and Fuel low pressure sensor circuit
    I will provide print screen if lol errors later
    I have unplugged the Nox sensor still same issue , engine can run 2 hours normal and then off from itself , u hear the engine like petrol is off and then engine stall ...
    Fuel low pressure sensor i have also unplugged same thing , engine keep running ok and then off ...
    No other errors appears
    No error in Immo
    No error on instrument : only the a short in + for the fuel gauge !? Can this cause engine to off !? Fuel gauge of course not working
    No error in gateway related to engine or Immo
    No error in transmission
    2-/ concerning error P0576 in 09 Electronics
    KL 15 showing active under live data
    I will post a photo of the relay Box J519 ...with KL15 print it on it but no relay is plugged , ignition is on all the time np with relay plugged or unplugged ( i brought a relay to try ) when i on the ignition i can feel the relay tik tak when it is plugged
    Is that relay a must there !? Or may be the car have electronic relay integrated inside the J519 !?
    Even the relay is plugged couldn't erase the P0576 !!!
    The car is mysterious
    With kind regards
    Adel
  4. Re: Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    Thank u Crasher for ur reply I will provide further details later , the car bought like that , i will ask previous owner and report
    With kind regards
    Adel
  5. Re: Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    [QUOTE=Crasher;1139866]KL15 is for line 15 so ignition live, without that relay you have no ignition power, why is it missing?[/QUOTE
    Sorry the scan is in French the laptop and the socket are not mine they r owned by a friend
    Code:
    Mardi,26,Avril,2022,00:01:10:58385
    VCDS -- Logiciel d'émulation de VAG/VAS sous Windows(R)
    Version VCDS: FRM 14.10.0.0
    Version données: 20141103
    VIN: WVWZZZ1KZ5W081784   Plaque d'immat.:
    Kilometrage: 122770km   Ordre réparation::
    Type chassis: 1K (1K0)
    Scanner: 01 02 03 08 09 15 16 17 19 25 26 36 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ5W081784   Kilometrage: 122770km
    00-Capteur d'angle de direction -- Etat: OK 0000
    01-Moteur -- Etat: Défaut 0010
    02-Boite auto -- Etat: Défaut 0010
    03-Freins ABS -- Etat: Défaut 0010
    08-Climatronic -- Etat: OK 0000
    09-Centrale Elec. -- Etat: Défaut 0010
    15-Airbags -- Etat: Défaut 0010
    16-Volant multifonct. -- Etat: OK 0000
    17-Instruments -- Etat: Défaut 0010
    19-Gateway CAN -- Etat: Défaut 0010
    25-Anti-démarrage -- Etat: OK 0000
    26-Toît ouvrant -- Etat: Impossible à contacter 1100
    36-Siège conducteur -- Etat: Impossible à contacter 1100
    42-Porte conducteur -- Etat: Impossible à contacter 1100
    44-Direction assistée -- Etat: OK 0000
    46-Module confort -- Etat: Défaut 0010
    52-Porte passager -- Etat: OK 0000
    56-Radio -- Etat: Défaut 1010
    62-Porte AR gauche -- Etat: OK 0000
    72-Porte AR droite -- Etat: OK 0000
    76-Aide au stationnt -- Etat: OK 0000
    Adresse 01: Moteur        Labels: Aucun
       No. pièce Log: 06F 906 056 CR    Mat: Hardware No
       Pièce: MED9.5.10       G00 7000
       Révision: 00000000    No. de série: VWZ7Z0D0546905
       Codage: 0000075
       No. Atelier: WSC 01392 785 00200
       VCID: 7BF974EF6AE560DB561-802E
       Sous-système 1 - Pièce: NOX  0000000000
       NOX  0000000000
    2 Codes défaut trouvés:
    29702 - Détecteur de NOx 1 banc 1 Aucune communication
                U1006 - 008 -  - Témoin allumé
    18972 - Transmetteur de press. carburant
                P2540 - 008 - souspression (G410) Signal implausible - Intermittent
    Tests passés: 0110 0001
    Adresse 02: Boite auto        Labels: 09G-927-750.clb
       No. pièce: 09G 927 750 EF
       Pièce: AQ 250 6F           0618
       Codage: 0000008
       VCID: 79F56EE760D952CB44D-802C
    1 Code défaut trouvé:
    01314 - calculateur moteur
                013 - Lire la mémoire de défauts - Intermittent
    Adresse 03: Freins ABS        Labels: 1K0-907-379-MK60-F.lbl
       No. pièce: 1K0 907 379 M
       Pièce: ESP FRONT MK60      0105
       Codage: 0021122
       VCID: 3C7BB7F32F6BA7E31FB-8069
    Adresse 08: Climatronic        Labels: 1K0-907-044.lbl
       No. pièce: 1K0 907 044 AC
       Pièce: ClimatronicPQ35 066 0404
       No. Atelier: WSC 00000 000 00000
       VCID: 68D33BA30B73DB43AB3-803D
    Aucun code défaut trouvé.
    Adresse 09: Centrale Elec.        Labels: 3C0-937-049-23-H.lbl
       No. pièce Log: 1K0 937 049 T    Mat: 1K0 937 049 T*
       Pièce: Bordnetz-SG 1.0 H30 0704
       Révision: 00030000    No. de série: 00000000941763
       Codage: E58D8F0600041800001400001400000000
       VCID: 4083C3034383C303433-8015
       Sous-système 1 - No. pièce: 1K1 955 119 B  Labels: 1KX-955-119.CLB
       Pièce: Wischer VW350  012  0401
       Codage: 00065493
       Sous-système 2 - No. pièce: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Pièce: RegenLichtSens 005  0605
       Codage: 00217125
    5 Codes défaut trouvés:
    01331 - Calculateur de porte côté conducteur (J386)
                004 - Aucun(e) signal / communication
    00830 - Calculateur pour ouverture/fermeture de capote (J256)
    01335 - Calculateur de position du siège / miroir conducteur (J543)
    00576 - Borne 15
                012 - Défaut électrique dans le circuit électrique
    00988 - Ampoule de feu stop droit (M10)
    Adresse 15: Airbags        Labels: 1K0-909-605.lbl
       No. pièce Log: 1K0 909 605 H    Mat: 1K0 909 605 H
       Pièce: 01 AIRBAG VW8   023 0700
       Révision: 06023000    No. de série: 00385D0JZAFM
       Codage: 0012337
       No. Atelier: WSC 01371 785 00200
       VCID: 316596C7F8295A8BBCD-8064
       Sous-système 1 - No. de série: 6332MSME1B1B7404
       Sous-système 2 - No. de série: 6342MSME0C456A02
       Sous-système 3 - No. de série: 6351HSME1B463703
       Sous-système 4 - No. de série: 6361HSME6B425903
    01217 - Détonateur d´airbag latéral côté conducteur (N199)
                001 - Valeur limite supérieure dépassée - Témoin allumé
    Adresse 16: Volant multifonct.        Labels: 1K0-953-549-MY8.lbl
       No. pièce Log: 1K0 953 549 A    Mat: 1K0 953 549 A
       Pièce: Lenksäulenmodul 500 0030
       Codage: 0010042
       VCID: 306393C3F3235383B33-8065
    Adresse 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       No. pièce: 1K0 920 861 A
       Pièce: KOMBIINSTRUMENT VDD 0814
       Codage: 0003103
       No. Atelier: WSC 15381 875 92383
       VCID: 2751789FC6ED143B629-8072
    3 Codes défaut trouvés:
    00771 - Transmetteur d´indicateur de niveau de carburant -G
                010 - Rupture/c.c. au pôle +
                004 - Aucun(e) signal / communication - Intermittent
    Adresse 19: Gateway CAN        Labels: 1K0-907-530-V1.clb
       No. pièce Log: 1K0 907 530 E    Mat: 1K0 907 951
       Pièce: Gateway         H09 0110
       Révision: 09          No. de série: 27001048250E6B
       Codage: 3F7F2740070002
       VCID: 29557EA7D0F9224B74D-807C
                 Capture:
                        Etat du défaut: 01100100
                        Priorité du défaut: 2
                        Fréquence du défaut: 4
                        Compteur de RAZ: 0
                        Kilometrage: 122744 km
                        Heure: 0
                        Date: 2000.00.00
                        Temps: 01:55:02
                 Capture:
                        Compteur de RAZ: 0
                        Heure: 0
                        Date: 2000.00.00
                        Temps: 01:55:02
                 Capture:
                        Fréquence du défaut: 18
                        Compteur de RAZ: 0
                        Heure: 0
                        Date: 2000.00.00
                        Temps: 01:55:06
    01305 - Bus de données Infotainment
                 Capture:
                        Etat du défaut: 00100100
                        Priorité du défaut: 1
                        Fréquence du défaut: 41
                        Compteur de RAZ: 40
                        Kilometrage: 122758 km
                        Heure: 0
                        Date: 2000.00.00
                        Temps: 03:14:25
    01304 - autoradio
                 Capture:
                        Fréquence du défaut: 34
                        Compteur de RAZ: 40
                        Heure: 0
                        Date: 2000.00.00
                        Temps: 03:14:56
    Adresse 25: Anti-démarrage        Labels: 1K0-920-xxx-25.clb
       Pièce: IMMO            VDD 0814
    Adresse 26: Toît ouvrant
    Adresse 36: Siège conducteur
    Adresse 42: Porte conducteur
    Adresse 44: Direction assistée        Labels: 1Kx-909-14x-44.clb
       No. pièce: 1K1 909 144 G
       Pièce: EPS_ZFLS Kl.2       1401
       VCID: 2F6190BFEE1D4C7BAA9-807A
    Adresse 46: Module confort
    Adresse 52: Porte passager
    Adresse 56: Radio
    Adresse 62: Porte AR gauche
    Adresse 72: Porte AR droite
    Adresse 76: Aide au stationnt        Labels: 1K0-919-283.lbl
       No. pièce: 1K0 919 283 A
       Pièce: 03 Einparkhilfe     0101
       VCID: 2D5D8AB7E4113E6B985-8078
    Fin-------------------------(Temps écoulé: 01:58)--------------------------
  6. Re: Golf MK5 FSI P0576
    108 Post(s)
    1816 Post(s)
    Hopefully I will have the wiring diagrams open later, finally!
  7. Re: Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    Thank u for all the help u provide
    Here also i could make photos of the KL15 on the relay box , which was empty , no relay plugged and i have plugged one like in my photo but P0576 stay
    Pls see link below for relay photo
    https://files.fm/u/5cj5gfvjm
    Regards
    Adel
  8. Re: Golf MK5 FSI P0576
    108 Post(s)
    1816 Post(s)
    In location KL15 your car must have a group 460 relay fitted, VAG part number 1K0 951 253 A.
  9. Re: Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    Ok, so she haven't before and i brought that one from the yard and i have plugged... But even without that relay (KL15) the car open ignition and start normally !!!!
    No difference with or without that relay even the P0576 fault stays on
    Regards
    Adel
  10. Re: Golf MK5 FSI P0576
    Jun 2017
    Morroco
    6 Post(s)
    Looking forward to get ur help...
    Regards
    Adel
  1. Replies: 0
    Last Post: 30-04-2021, 06:42 PM
  2. Replies: 0
    Last Post: 06-11-2020, 01:53 PM
  3. Replies: 0
    Last Post: 14-09-2020, 03:08 PM
  4. More space, more Golf: World premiere of the new Golf Estate and Golf Alltrack
