On LHD the convenience “comfort” unit is still behind the glovebox on a bracket secured to the heater unit ducting.
Ok here is my update
1- car left whole night without battery , nothing changes
2 - installed a used Comfort unit taking from another car , coding done erase error still the same issue : no communication with 46 Comfort no communication with driver and passenger door and roof module
The Door won't lock and unlock even the rear right door which was working before !!!
3- i also swapped a used gateway from another car with same part number , coding done , erase error and still get the same
No communication driver door passenger door , roof etc
Now when i have tested after i put back my control unit as the new one haven't solved my issue , the 2 right doors lock and unlock ! passenger and rear
Driver door and left rear door not working
My guessing is that i need to replace the driver door control unit !
My concern is that all this modules swapped and still getting same thing , no communication with control unit , windows are not working , roof not working, AC not working , electric mirrors not working ....
Pls help and advise
Regards
Adel
