Thread: vw passat 2002 1.9 4 motion sport
Results 11 to 20 of 26
  1. Re: vw passat 2002 1.9 4 motion sport
    Apr 2022
    tyne wear
    Hi thanks for that info
    do
    tou have any info on the rears
    also the length of the springs
    thanks wit
  2. Re: vw passat 2002 1.9 4 motion sport
    108 Post(s)
    1816 Post(s)
    The rear springs are 3B0 511 115 AJ and also obsolete, not available from anyone aftermarket or even from VW Classic. About the only people I can think who will be able to help are Spring Manufacturers Sheffield | Suspension, Compression, Extension & Torsion Springs who have made springs for me to order in the past.
  3. Re: vw passat 2002 1.9 4 motion sport
    Apr 2022
    tyne wear
    Thanks for that mate
    Have you any idea of the ride hight on the 4 motion sport as to a standard 4 motion
    Or even know the length of the spring you have gave part number for.
    I have spoke to vw they discontinued parts as not a lot
    Of sport models made
    Thanks Will
  4. Re: vw passat 2002 1.9 4 motion sport
    Apr 2022
    tyne wear
    Quote Originally Posted by william c View Post
    Thanks Will
    has any member a standard passat 2000 2005 passat eatate that could measure from ground to onder wheel arch front rear and give me the hights plesae
    so i can try work out the sports ride hight
    thanks will
  5. Re: vw passat 2002 1.9 4 motion sport
    108 Post(s)
    1816 Post(s)
    Remind me Tuesday, the info is on my work PC.
  6. Re: vw passat 2002 1.9 4 motion sport
    Apr 2022
    tyne wear
    Hi thanks
    Just a quick reminder
    Thanks Will
  7. Re: vw passat 2002 1.9 4 motion sport
    #17
    108 Post(s)
    1816 Post(s)
    There is no info on ELSA but I used to be the UK importer for Weitec suspension many years ago and I found some spread sheets from 2003 for ride heights which shown the standard heghts being 390mm front and 395mm rear and the sports system as being 340mm front and 350mm rear, how accurate that data is I don't know but they are almost the exact figures I would have guessed at if I had to.
  8. Re: vw passat 2002 1.9 4 motion sport
    #18
    Apr 2022
    tyne wear
    Ok thanks for your time
    Willn
  9. Re: vw passat 2002 1.9 4 motion sport
    #19
    May 2012
    Everywhere
    308 Post(s)
    I will dig out my measurements before the Eibach went on .
  10. Re: vw passat 2002 1.9 4 motion sport
    #20
    May 2012
    Everywhere
    308 Post(s)
    2003 fwd Passat 1.9 tdi Sport with 16" Road America.
    From ground to arch 66cm both front and rear .
  1. 2002 Passat Tdi Sport
    By fire3 in forum In Car Entertainment
    Last Post: 22-05-2013, 10:18 AM
  2. Passat TDI Sport 4 Motion
    By doriclad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2011, 10:13 PM
  3. passat tdi sport 2002 various issues
    By aliuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2009, 03:24 PM
  4. vw passat tdi sport 2002
    By vw02 in forum New Member Introductions
    Last Post: 24-04-2008, 08:11 AM
  5. how to clean (MAF) ON TDI PASSAT 2002 SPORT
    By FAROOQS in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-01-2008, 04:53 PM
