Thread: Audi a6 c6 2.7 tdi esp fault. P0641
  1. Audi a6 c6 2.7 tdi esp fault. P0641
    Aug 2009
    Derry, Northern Ireland
    Hello,
    I have a fault with my 2010 a6 2.7tdi avant.
    I changer the xenon high/ low beam bulbs on Monday. I took the car out for a spin on Monday night to see how the new bulbs preformed. I had driven for around an hour and stopped the car for a while. When I tried to start the car it would trim over but wouldn't start.
    An esp fault came up on the dash. The heater plug sysn bol is flashing and the battery symbol is also on the dash
    I had to get recover to home and by the AA. The engineer tried to get me going before hand.
    He hooked up his pc and fault p0641 c
    I have fitted a new battery which made no difference.
    I am not sure what to do next.
    My mechanic will have a look at it next week.
    Has anyone experienced a similar issue.
    Kind regards.
  2. Re: Audi a6 c6 2.7 tdi esp fault. P0641
    Jul 2008
    Lisburn
    15 Post(s)
    was it only ESP or id the dash go mad? there is a relay that goes bad and has symptoms similar to the above.
    There is a few threads on here about it, i started one a few years back it should have a link tot he one with the relay to change out.
    it is a diy job and the relay is cheaper from the dealer at about £15 so worth a punt before someone changes out modules and can bus systems which some did when i looked into it.
    good luck
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Audi a6 c6 2.7 tdi esp fault. P0641
    Aug 2009
    Thank you for the reply. I will check out the post that you mentioned. There are a few faults showing up on the dash. My mechanic found a 20amp fused popped in the fuse box in the boot area which he replaced. It didn't change anything.
  4. Re: Audi a6 c6 2.7 tdi esp fault. P0641
    Mar 2010
    Derry ireland
    60 Post(s)
    Can you post up your engine code or reg no
  5. Re: Audi a6 c6 2.7 tdi esp fault. P0641
    Apr 2023
    Scotland
    Can you tell me what the relay was you changed ?? Or where it was located ? I have the same error and cars not starting at all.
  6. Re: Audi a6 c6 2.7 tdi esp fault. P0641
    Jul 2008
    Lisburn
    15 Post(s)
    J317
    Stewart
  1. Question P0641 code and the flashing wiggly light
    By Alex jb in forum Touran - Sharan - Caravelle
    Last Post: 05-08-2018, 07:24 PM
  2. Audi A4 abs fault
    By darrenowen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-07-2010, 11:50 AM
  3. Audi A6 Fault
    By jUsT2eXy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-08-2009, 12:20 PM
  4. Question Audi a3 ABS fault
    By CHAMBO25 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2009, 08:18 PM
  5. ABS FAULT (AUDI 80 TDi)
    By simon852 in forum 80 - 90
    Last Post: 17-10-2008, 09:33 PM
