Hi, Some warning lights came on the dash when my daughter was driving her new purchased 2015, Q3 S Line yesterday. The car still drove OK she said however, when they went to bring the car by for me to run a report on what the problem may be, all lights had gone off.
When I ran the VCDS on it, it came up with 5 faults... Any help you can give on same would be appreciated!
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
Ross-Tech: Home
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,17,April,2022,10:39:59:53769
VIN: WAUZZZ8U7FR048492 License Plate:
Mileage: 182440km-113362mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 25 2B 42 44 46 52 55 5F 62
6C 6D 72
VIN: WAUZZZ8U7FR048492 Mileage: 182440km-113362miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CUVC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 BG HW: 04L 907 309 K
Component: R4 2.0l TDI H20 2913
Revision: 8AH20--- CVN: B363B73A92F1EF3C
Coding: 02190032043501083000
Shop #: WSC 34281 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906016BG 004002
ROD: EV_ECM20TDI01104L906016BF_004.rod
VCID: 6FE6A401B64F05F726-803A
VINID: 9D196AAAA2251D688010810908D06E3011
No fault code found.
Readiness: 0 0 0 0 0 -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CA HW: 5N0 614 109 CA
Component: ESC-EBC460iV1 H08 0004
Serial number: A00TAG9
Coding: 21F124A18924C374207B840924C591C304345700F08B4884
Shop #: WSC 00049 770 00241
ASAM Dataset: EV_Brake1ESCEPBTRW 003039
ROD: EV_Brake1ESCEPBTRW_003.rod
VCID: 6CDCB30D8759FEEF03-8038
5 Faults Found:
0020 - Rear Right Wheel Speed Sensor
C101D 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 196
Mileage: 182430 km
Date: 2022.04.16
Time: 16:19:44
Additional_Codes: 09 6B 00 0D 6E 7F 00 4B 0A
DTC: 00 00 14
Additional2: 00 03 01 02 05 22 67 00 67 00
0028 - Rear Right Wheel Speed Sensor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 196
Mileage: 182430 km
Date: 2022.04.16
Time: 16:19:42
Additional_Codes: 06 8A 00 0D 6E 7F 00 4B 0A
DTC: 00 00 1C
Additional2: 00 05 01 02 05 22 67 00 67 00
0032 - Rear Right Wheel Speed Sensor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 196
Mileage: 182429 km
VCDS
Self-Diagnosis Log
Page 4
Date: 2022.04.16
Time: 16:17:13
Additional_Codes: 15 F4 00 0C F5 7F 00 48 02
DTC: 00 00 20
Additional2: 00 05 01 00 05 22 5A 00 5A 00
0036 - Rear Right Wheel Speed Sensor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 196
Mileage: 182430 km
Date: 2022.04.16
Time: 16:20:11
Additional_Codes: 17 9C 00 0D 7D 7F 00 4B 0A
DTC: 00 00 24
Additional2: 00 05 01 02 05 22 64 00 64 00
0768 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 182430 km
Date: 2022.04.16
Time: 16:17:23
Additional_Codes: 0B 59 00 0E E5 7F 40 4B 0A
DTC: 00 03 00
Additional2: 00 03 01 02 05 22 60 00 60 00
VCDS
Self-Diagnosis Log
Page 5
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0365966151
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 37765C618E9F8D373E-8062
No fault code found. -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log
Page 6
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 G HW: 8U0 820 043 G
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043G
VCID: 356A56695C937F272C-8060
2 Faults Found:
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 174093 km
Time Indication: 0
Date: 2021.11.04
Time: 18:59:40
Freeze Frame:
Voltage: 13.30 V
(no units): 96.0
Temperature: 9.0°C
01810 - Actuating Motor for Temperature Flap; Right (V159)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 192
Mileage: 182290 km
Time Indication: 0
Date: 2022.04.15
Time: 15:11:19
Freeze Frame:
Voltage: 12.50 V
Temperature: 27.0°C
(no units): 29.0
(no units): 63.0
Temperature: 15.5°C
VCDS
Self-Diagnosis Log
Page 7
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AC113817
Coding: 4E000A2FA805F1C0201849C82184014C53F327AA216F81BBE4 088784E0C5
Shop #: WSC 00049 770 00010
VCID: 7CFC834DFF396E6F93-8028
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 150412 H37 0090
Serial number: 150422072846
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23924048
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 19
Reset counter: 156
Mileage: 182124 km
Time Indication: 0
Date: 2022.04.12
Time: 20:28:01
Freeze Frame:
Term 15 Off
Voltage: 12.35 V
OFF
ON
Term 50 Off
OFF
OFF
VCDS
Self-Diagnosis Log
Page 8
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 8U0 919 475 A HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0050
Revision: -------- Serial number: 56291509104207
Coding: 381209
ASAM Dataset: EV_EPHVA2CAU3160000 003004
ROD: EV_EPHVA2CAU3160000_003.rod
VCID: 418232B9D05BC38780-8014
1 Fault Found:
13637397 - Databus
U1123 00 [008] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 182429 km
Date: 2022.04.16
Time: 16:17:13
VCDS
Self-Diagnosis Log
Page 9
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 C HW: 8U0 959 655 C
Component: AirbagVW-AU10 H09 0900
Serial number: 003PAR0B83GH
Coding: 30523232333030303030554A305238553053
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_AirbaAU10SMEAU316 001010
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 47962CA1FE7FFDB74E-8012
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.V H02 ----
Serial number: 3496KSME62587136ZZZY
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.V H02 ----
Serial number: 3506KSME73081A37ZZZR
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME4A6C7136ZZZ
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME7F081A37ZZZ+
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Component: F.Sens.Fahr H02 ----
Serial number: 3555USME7B790035ZZZ1
VCDS
Self-Diagnosis Log
Page 10
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 K HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0162
Revision: FF010018 Serial number: 20150421300240
Coding: 1004204000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 448C3BADCF49D6AFAB-8010
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Component: E221 - MFL H08 0010
Serial number: 18 04 2015 D0055286
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 980 G HW: 8U0 920 980 G
Component: KOMBI_MEDIUM H03 0470
Serial number: 00000000000000
Coding: 42CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 408437BDDB51CA8F8F-8014
VCDS
Self-Diagnosis Log
Page 11
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AS HW: 8U0 907 468 J
Component: GAT 4CAN 2L M H13 0090
Revision: 1R160041 Serial number: 4141R1540200E0
Coding: FBCF1A5A050B0D610353
VCID: 132EC8F1F2A7811762-8046
Subsystem 1 - Part No SW: 8U0 959 591 A HW: 8V3 959 591 A
Component: J245 PS11.403 H03 0004
Serial number: 0000FST0009JYC200000
Coding: 901E00
Subsystem 2 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 42120E57271491901740
Subsystem 3 - Part No SW: 8U0 959 591 A HW: 8V3 959 591 A
Component: J394 PS11.403 H03 0004
Serial number: 0000FST0009JXUJ00000
Coding: 801E00
Subsystem 4 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 15121000622011200181
No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8U0 857 511 B HW: 8U0 857 511 B
Component: FLA H03 0012
Revision: AA002001
Coding: 04020A64747464545425363E00
VCID: 3A704555B58D905FC1-806E
VCDS
Self-Diagnosis Log
Page 12
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H03 0470
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000116136003
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3064677D6BF15A0F7F-8064
No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Revision: -------- Serial number: --------------
Coding: 011E16201C01000000
VCID: 52A00DF50D3D481F29-8006
VCDS
Self-Diagnosis Log
Page 13
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
Shop #: WSC 00049 770 00154
VCID: 408437BD1351CA8F8F-8014
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 182429 km
Time Indication: 0
Date: 2022.04.16
Time: 16:17:13
Freeze Frame:
Voltage: 12.88 V
DU
Temperature: 38.0°C
RPM: 2150 /min
Speed: 56.0 km/h
Speed: 56.0 km/h
Count: 0
------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011E16201E01000000
VCID: 51A202F9083B330710-8004
VCDS
Self-Diagnosis Log
Page 14
Address 55: Headlight Range (J745) Labels:| 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 G HW: 7P6 907 357 B
Component: AFS-ECU H01 0031
Coding: 089E00102B200200
ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
ROD: EV_HeadlRegulLEDAFSPt.rod
VCID: 38745F5D8381824F37-806C
Left LED Headlamp Power Output Stage 1:
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02500
Right LED Headlamp Power Output Stage 1:
Subsystem 2 - Part No SW: 7PP 941 572 AA HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H08 0002
Coding: E02500
Left Headlamp Power Output Stage:
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E02500
Right Headlamp Power Output Stage:
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E02500
1 Fault Found:
13705987 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 196
Mileage: 182429 km
Date: 2022.04.16
Time: 16:17:13
VCDS
Self-Diagnosis Log
Page 15
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8U1 035 192 A HW: 8U1 035 192 A
Component: RMC Nav Plus H61 0139
Coding: 0101060002C157470823020103010000000000
VCID: 336E687192E7611702-8066
Subsystem 1 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018
Serial number: AUZ8ZDFM503CL60
1 Fault Found:
01609 - Cooling Fan in Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 182168 km
Time Indication: 0
Date: 2022.04.12
Time: 20:58:29
Freeze Frame:
ON Time: 4765 h
------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8X0-959-795.clb
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H08 0415
Coding: 010E16200001000000
VCID: 4FA604811E0F25F706-801A
No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 8U0 907 441 HW: 8U0 907 441
Component: SG Rueckfahrkamera 0031
Revision: --H09--- Serial number: 525 PA8JA3H2ZU
Coding: 1080015
Shop #: WSC 02391 785 00012
VCID: 76E891650115343FE5-8022
VCDS
Self-Diagnosis Log
Page 16
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 8U0 959 107 HW: 8U0 959 107
Component: HDSG-Modul H01 0549
Revision: 15001001 Serial number: 108501493
Coding: 183307C022
ASAM Dataset: EV_HDSGAU316 001001
ROD: EV_HDSGAU316.rod
VCID: 7CFC834DF7396E6F93-8028
No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8X0-959-795.clb
Component: TSG HR H08 0415
End-------------------------(Elapsed Time: 03:48)-------------------------
