Thread: Losing coolant cdud engine
Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. Re: Losing coolant cdud engine
    #31
    134 Post(s)
    2007 Post(s)
    If it is a head gasket you will find it impossible to know which one and it is a HUGE engine out job. The heads cannot be skimmed so must be replaced, even the list of parts writes the car off never mind the 40 or so hours labour. You also need a pile of specialist tools.
  2. Re: Losing coolant cdud engine
    #32
    Jul 2008
    Lisburn
    16 Post(s)
    Thinking the best way out here for Scott.
    A dynamic compression check would probably only show a head gasket if it was really bad and if it was, there would be other symptoms.
    what about an EGR blank? bit of work to get to the Y of the up pipes ( take the turbo off, correct me if im wrong crasher) but DIYable and if it was a head gasket it would less money wasted then fitting a new EGR cooler?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Losing coolant cdud engine
    #33
    134 Post(s)
    2007 Post(s)
    I would unplug the EGR valve to shut it down (this will generate an error) and then clamp the coolant hoses to see if the gases still register but I have never has much success with those kits even from Snap On as the coolant boils up into the tester and corrupts it
  4. Re: Losing coolant cdud engine
    #34
    Jun 2021
    GB
    Sorry to you both, been struggling with Internet!.
    I have actually taken off the egr cooler. The actual tubes in the cooler are made of stainless steel and look in decent condition. However, around the bottom of the tube assembly is a rubber gasket which separates the gases from the water. On the gases side the rubber does seem harder and also has tiny cracks. On the water side is better condition except 1 bigger split. Although the cracks are not all the way through, I can't help thinking this is not going to help. I will be giving it a pressure test when at work and will keep you all posted. My immediate question is, are these gaskets available anywhere!
    I have included photos of the gaskets. The 2 gaskets with holes are metal.
    Sent from my SM-G991B using Tapatalk
  5. Re: Losing coolant cdud engine
    #35
    Jan 2022
    oldham
    Well, long time posting. Fitted a new egr cooler from tps. Problem still there. Had it in audi. They were useless and didn't act on my issues, instead pointing out a coolant leak from a pipe I had managed to break and said that was why the coolant was leaking! I'm tearing my hair out now! Am I right in thinking the only places that the engine can pressurise the coolant is through egr cooler and cylinder head? Or is there somewhere else I could check?
    Sent from my SM-S911B using Tapatalk
  6. Re: Losing coolant cdud engine
    #36
    Jan 2022
    oldham
    Also, is it possible to remove cylinder heads in situ?
  1. 55 1.9tdi 105 touran losing coolant, heaters not working and engine fan
    By rossyjr in forum Touran - Sharan - Caravelle
    Last Post: 22-02-2017, 09:57 PM
  2. A6 1.9 TDI losing coolant
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-12-2015, 01:52 PM
  3. Losing coolant
    By Cannondave in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2015, 09:39 AM
  4. losing coolant between engine and firewall
    By lekkasje in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-10-2012, 12:18 PM
  5. '02 reg TDi 130 losing oil and coolant
    By nico in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2007, 10:01 PM
