Thread: Losing coolant cdud engine
Results 11 to 20 of 36
  1. Re: Losing coolant cdud engine
    Jul 2008
    Lisburn
    16 Post(s)
    holding pressure overnight?!?!
    does the level change if you hold a few revs for a short time then let go (with the cap off)?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  2. Re: Losing coolant cdud engine
    Jun 2021
    GB
    I'm not sure about that I will give that a try in the morning when the engine is cold. I do have some fault codes too. I'll post shortly
    Sent from my SM-G991B using Tapatalk
  3. Re: Losing coolant cdud engine
    Jun 2021
    GB
    Here are my codes. Hope thus helps
  4. Re: Losing coolant cdud engine
    Jul 2008
    Lisburn
    16 Post(s)
    Lol holding pressure overnight..... from a pressure test I am now guessing? Not from normal running I hope.
    Stewart
  5. Re: Losing coolant cdud engine
    Jun 2021
    GB
    Sorry, I should have been more clear. Not had pressure test, just opened cap after being stood overnight and there was an escape of air and the coolant rose a little
  6. Re: Losing coolant cdud engine
    Jul 2008
    Lisburn
    16 Post(s)
    that doesn't sound right, i would imagine there may be a small bit of pressure after some time - but not enough to change coolant level?
    Stewart
  7. Re: Losing coolant cdud engine
    #17
    Jun 2021
    GB
    Same again this morning. Not alot of pressure but enough to raise in tank about 10mm. Then at work after short drive, opened cap and pressure brought it back upto minimum
  8. Re: Losing coolant cdud engine
    #18
    Jun 2021
    GB
    Hi swalker. I stated car with expansion tank cap off this morning and revved a few times. It did nothing to the levels. I've not come to work in it today so I couldn't rev it again while warm with cap off. It's really frustrating me
  9. Re: Losing coolant cdud engine
    #19
    Jul 2008
    Lisburn
    16 Post(s)
    ok so we are wondering off here? reset time.
    the fault code you posted is from January, did you clear it and has any returned.
    whats the current symptoms of your fault?
    Stewart
  10. Re: Losing coolant cdud engine
    #20
    Jun 2021
    GB
    I cleared the codes, and they came back. I can do another scan tonight when I'm home. I am right in thinking the coolant pump in the codes is the one under the windscreen ? It has been replaced with genuine part from audi dealer.
  1. 55 1.9tdi 105 touran losing coolant, heaters not working and engine fan
    By rossyjr in forum Touran - Sharan - Caravelle
    Last Post: 22-02-2017, 09:57 PM
  2. A6 1.9 TDI losing coolant
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-12-2015, 01:52 PM
  3. Losing coolant
    By Cannondave in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2015, 09:39 AM
  4. losing coolant between engine and firewall
    By lekkasje in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-10-2012, 12:18 PM
  5. '02 reg TDi 130 losing oil and coolant
    By nico in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2007, 10:01 PM
