Thread: A4 Timing Belt Change Interval
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: A4 Timing Belt Change Interval
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Good price. Maybe for peace of mind? Anyhoo, up to you.
  2. Re: A4 Timing Belt Change Interval
    May 2016
    Portsmouth
    Mines due on the v6 tdi 2002 , only covered approx 20k but it’s been 5 years , I’m getting quotes of around £1.1k for the full INA kit including lots of tensions and pullies etc
  3. Re: A4 Timing Belt Change Interval
    1840 Post(s)
    Difficult one as VAG no longer say five years but I don’t have the spec for that to hand. My business partner has a 2005 AllRoad and we did that at six years. £1100 is about right but would not cover and unforeseen problems such as poly V tensioner pivot wear or a are case of the fan drive hub bearing being worn which is £395 and genuine only.
  4. Re: A4 Timing Belt Change Interval
    May 2016
    Portsmouth
    Yeah they’ve already placed on quote costs could increase if other problems or things are found , they also aren’t sure if the INA pump they are supplying is a metal blade or plastic blade type , last one I fitted was INA metal.
    Do you know if INA offer a choice in material for the pump? As I have the part number that matches the OE Audi one but the INA listings don’t seem to mention the blade compound
    Audi is 059 121 004
    INA equivalent is 538 034 910
    They match up as same part but visually the Audi is plastic and most pictures of the INA show a silver colour or obvious metal blade but not any wording confirming it’s metal
    Any idea mate? Worse case they can simply order one and see they just being a bit ****** saying if I don’t like their parts I can supply them lol and it’s not that Iv told them just trying to confirm so they can supply.
  5. Re: A4 Timing Belt Change Interval
    1840 Post(s)
    We use the Febi kit, I don’t care if the impeller is sheet metal, cast or moulded plastic.
  6. Re: A4 Timing Belt Change Interval
    May 2016
    Portsmouth
    No problem mate, I’ll be doing the job anyways even thought it’s only 5 years/20k just for peace of mind
    And I’ll have to just order the INA pump to visually check I guess
  1. Timing belt interval?
    By jmurray01 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-04-2019, 08:53 PM
  2. Timing Belt Interval
    By phy7tes in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-11-2016, 08:21 PM
  3. Please Help Timing belt interval's
    By JON35Y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2012, 05:24 PM
  4. A4 B7 Timing Belt Interval
    By whammer007 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-04-2011, 07:14 AM
  5. Timing belt interval?
    By mattiustherebel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2010, 10:49 PM
