Thread: Vw passat cc 2009 turbo actuator
  1. Vw passat cc 2009 turbo actuator
    Mar 2020
    ireland
    6 Post(s)
    Hi all, looks like im fed up with my coil light and error message on dash "Engine fault visit workshop" Fault Code P2563
    so im trying to figure out what the part number is! my engine code is Cba on the timing belt cover. the actuator itself doesnt seem to have any searchable number 😭.
    mister auto is telling me 03L253016KX is the part number for it?
    These are the Aftermarket options listed
    meat and doria 64064
    A.I.C 56295
    Storm 97999
    Vemo V15-40-0001
    meat and doria 64065 is also listed as compatible on their own website but i cannot tell the difference between them!
    my VIN is WVWZZZ3CZ9E518648
    Id normally use OEMEPC but the website is not working.
  2. Re: Vw passat cc 2009 turbo actuator
    1840 Post(s)
    Your engine is a CBAB and the actuator kit you need is 03L 198 716 L
  3. Re: Vw passat cc 2009 turbo actuator
    Mar 2020
    ireland
    6 Post(s)
    Thanks crasher! im lost without oemepc, i have been searching and the meat and doria 64064 has that number listed as compatible it is €92 delivered, i looked at O.E on ebay and it is approx €240 delivered. the actuator in my car is not O.E going off the crazy part number that is affixed vs the number Stamped on the one listed on ebay! I dont think Vw will sell the actuator separate to the turbo.
  4. Re: Vw passat cc 2009 turbo actuator
    1840 Post(s)
    We use the genuine kit
  5. Re: Vw passat cc 2009 turbo actuator
    Mar 2020
    ireland
    6 Post(s)
    I took a gamble on the meat and doria actuator, i fitted it without vag com, no error codes or pending car is driving well! but i lost the securing tab to stop the bolts from loosening. as careful as i was i dropped it and it is now in no mans land. are these stocked in VW? or do you have a part number handy. ive tightened them bolts up as much as i dared hoping they wont vibrate loose while im driving about
  6. Re: Vw passat cc 2009 turbo actuator
    1840 Post(s)
    Not available as a spare, in fact they don't tell you to reuse it, you use the green locking paint included in the kit.
  7. Re: Vw passat cc 2009 turbo actuator
    Mar 2020
    ireland
    6 Post(s)
    I only got the actuator in the box no kit with it, i followed your guide that you posted on another thread but i didn't remove oil pipe just the intake pipe, to be honest i'm surprised i don't have a light on the dash as i had no vcds or vacuum pump! i managed to put some tread lock on below the nut so fingers crossed it doesnt come loose!
    the car feels more powerful now boost is more apparent felt bit dead before so all good now.
    Thanks for all your input crasher would have been lost without it!
  1. P3348 Turbo Actuator doesn't move, new turbo and actuator installed too!!!
    By alan0259 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-10-2021, 03:38 PM
  2. Question Audi A4 B8 2009 Variable Cam Lift Actuator Identification
    By Davmar in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-06-2019, 05:59 PM
  3. Please Help 2.0tdi turbo actuator 2009 a4
    By bigred84 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2017, 11:37 PM
  4. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  5. Passat 2008 turbo actuator fault
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2014, 07:09 PM
