Thread: Drivers side heater blowing warm only
  1. Post Drivers side heater blowing warm only
    Apr 2007
    Bedfordshire
    Good afternoon,
    A6 saloon V6 3.0L TDI 2012
    My A6 will only blow warm on drivers side (passenger side works normal) from all vents. The dial is not digital and will turn down to cold but on maximum 24 it is actually only about 10 degrees. This started suddenly and my local reliable garage have tested the heating system and have said there is no faults showing and suggested something may be blocking a vent which would mean removing all the dash with considerable labour charge just to expose/diagnose.
    I'd appreciate and advice/help please.
    Steve.
  2. Re: Drivers side heater blowing warm only
    133 Post(s)
    1986 Post(s)
    Could you private message me the reg or post the VIN?
  3. Re: Drivers side heater blowing warm only
    133 Post(s)
    1986 Post(s)
    Get the HVAC system scanned for fault codes, the air blend flap servo motors are prone to failure plus ask the person doing the read to look at the air outlet temperature sensor values to make sure they make sense. If nothing shows up then you are looking at a partially blocked heater matrix.
  4. Re: Drivers side heater blowing warm only
    Apr 2007
    Bedfordshire
    Thanks Crasher
    I’ll get them to check faults you’ve suggested. If the matrix is partially blocked what’s the best treatment for that ?
    cheers Steve
  5. Re: Drivers side heater blowing warm only
    133 Post(s)
    1986 Post(s)
    Replacement which is a total nightmare, back flushing rarely works on modern heater matrix's.
  1. Heater only blowing warm air, No Cold Air!!
    By taffjohn in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-07-2013, 10:46 PM
  2. Please Help Heater unit only blowing warm air
    Last Post: 07-07-2013, 03:11 PM
  3. 02 Sharan heater blowing warm air
    By peerieivan in forum Touran - Sharan - Caravelle
    Last Post: 25-01-2013, 06:12 PM
  4. Question heater blowing warm when set to cold
    By williamjack in forum Golf MK5 - 2004 - 2009
    Last Post: 16-08-2012, 01:15 PM
  5. Passenger side climate control blowing hot, drivers side ok
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2009, 10:44 PM
