Thread: Audi A7 313hp BiTDI Boost controller issue
Results 1 to 8 of 8
  1. Red face Audi A7 313hp BiTDI Boost controller issue
    Apr 2022
    Sweden
    I'm having issues with my Audi A7 313hp BiTDI 2013. After I have been driving more than half an hour and stopped for a short while (or forgot to deactivate the start/stop function) it's going into limp mode directly after start and the glow plug light is flashing. At cold start or if I don't turn it off I can drive it forever without any issues at all, no matter if I'm driving like an old lady or a huligan, runs perfectly.
    OBD test shows P004A00 - Turbocharger/Supercharger Boost Control Solenoid “B” Circuit/Open - Intermittent
    Does anyone know where I can locate it and the correct part number?
    Is this one of the small vacuum solenoid valves on top of the engine right next to the intake manifold under the plastic cover?
    Thanks!
  2. Re: Audi A7 313hp BiTDI Boost controller issue
    1840 Post(s)
    Can you post or private message me the VIN?
  3. Re: Audi A7 313hp BiTDI Boost controller issue
    Apr 2022
    Sweden
    It is WAUZZZ4G0DN117317
  4. Re: Audi A7 313hp BiTDI Boost controller issue
    1840 Post(s)
    Remind me tomorrow but I probably need to look this up on ELSA which I am waiting for a new copy to arrive, those turbo’s are highly complex.
  5. Re: Audi A7 313hp BiTDI Boost controller issue
    Apr 2022
    Sweden
    Thanks!
  6. Re: Audi A7 313hp BiTDI Boost controller issue
    1840 Post(s)
    My copy of ELSA has still not arrived...
  7. Re: Audi A7 313hp BiTDI Boost controller issue
    Apr 2022
    Sweden
    Problem solved
    Might help someone to know that I just changed the solenoid that regulates the wastegate vacuum, partnumber 059906627M / VG34010835E
  8. Re: Audi A7 313hp BiTDI Boost controller issue
    1840 Post(s)
    And I STILL can’t get ELSA to work!
  1. Question please can someone check the connections on the boost controller (newer n75 valve)
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2011, 11:19 PM
  2. boost controller on a diesel????????
    By zlr177 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-08-2009, 11:15 PM
  3. Question Electronic boost controller
    By guthner1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2008, 09:35 PM
  4. (mbc) manual boost controller on 1.8t
    By sharpy1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2008, 11:01 PM
  5. Anyone using a boost controller?
    By Foilpact in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-03-2008, 06:43 PM
