Thread: Front Consul Bracket / Bushes Replacement
Results 1 to 10 of 15
  1. Front Consul Bracket / Bushes Replacement
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi do my front consul bracket bushes are knackered and need replacing.
    What’s the process to replace these please?
    I’ve not found it in the workshop manual but shall keep looking.
  2. Re: Front Consul Bracket / Bushes Replacement
    1836 Post(s)
    I can't remember which transmission you have. You have to remove the wishbone and before removing the inner two rear consul bolts you must fit alignment pins into the outer bolt position to maintain the setting. The two M10 inner bolts go right through the main consul and can snap leaving about 50mm of snapped bolt in the main consul. The rear bushes are supposed to pull off, they often don't. For speed in the workshop we just fit a complete new Febi Golf 6 style arm with ball joint.
  3. Re: Front Consul Bracket / Bushes Replacement
    1836 Post(s)
    Manual, remember every single bolt is one time only
  4. Re: Front Consul Bracket / Bushes Replacement
    Jul 2018
    8 Post(s)
    Thank you what’s the part number for the Febi complete arm you mention?
  5. Re: Front Consul Bracket / Bushes Replacement
    Jul 2018
    8 Post(s)
    Also how are you supposed to replace the part if you have to keep an alignment pin (T10096) in position?
  6. Re: Front Consul Bracket / Bushes Replacement
    1836 Post(s)
    38180 and 38181 but I have just checked and there is no UK stock of the 38181 at Febi themselves but some dealers may have stock, the prices are all over the place, Aut0doc's price is less than UK Febi dealer buy in price!
  7. Re: Front Consul Bracket / Bushes Replacement
    Jul 2018
    8 Post(s)
    Thank you for the part numbers I’ll take a look on *******. ECP have Lemförder for ~£100 (I have sheet steel arms I think).
    Makes me think should I just end up polybushing…..a lot of work but is it worth it?
  8. Re: Front Consul Bracket / Bushes Replacement
    Jul 2018
    8 Post(s)
    Do febi do a bolt kit as well? Or should I just get original?
  9. Re: Front Consul Bracket / Bushes Replacement
    1836 Post(s)
    I can't see one listed on that which is unusual but they have a Pro kit for the forged steel and aluminium arms you can use but that's OTT on yours.
    2 x N 101 410 03
    2 x
    N 910 398 02
    4 x N 105 797 02
  10. Re: Front Consul Bracket / Bushes Replacement
    Jul 2018
    8 Post(s)
    Thanks for the part number confirmation.
    Regarding the alignment pin T10096 I am still not clear how this is used?
    If the alignment pin is in you can’t remove the lower arm?
  1. Front wishbone - bracketed bushes replacement
    By VAG-Abound in forum Golf MK5 - 2004 - 2009
    Last Post: 12-12-2019, 11:06 AM
  2. Front anti roll bar bushes replacement on B7
    By smartecosse in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 02-01-2019, 04:45 PM
  3. Polo 9N - Replacement front ARB and suspension bushes
    By GUEST 9999 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-01-2016, 01:21 AM
  4. Question 2001 Allroad 2.5TDI (AKE) Vaned pump bracket replacement.
    By 70chips in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-01-2015, 10:13 PM
  5. Front DS caliper mounting bracket
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2010, 11:30 AM
