Thread: Not starting straight away
  1. Not starting straight away
    Mar 2022
    My 2.0 TDi bluemotion struggles to start sometimes. It keeps trying and then it will go. The start stop alarms. I turn it off and start again and it goes straight away. Anyone have this and solved. Have had the crank speed sensor replaced but no change. Thanks in advance.
  2. Re: Not starting straight away
    Mar 2021
    Ripon
    7 Post(s)
    Quote Originally Posted by MDickson View Post
    Have you checked for any fault codes with a scanner or obd dongle? Does this happen only on cold starts or also when the engine is warm? Start stop failure could point to the battery charge being low. How old is the battery? Bloody intermittent faults, they do my nut in!
  3. Re: Not starting straight away
    Mar 2022
    Quote Originally Posted by Mittens247 View Post
    I have not scanned it since the crank speed sensor was replaced. I assume the garage checked and cleared any codes.
    I shall try and find a code reader that works and check.
  1. In need of a straight edge
    By patrick_c99 in forum South West England
    Last Post: 24-01-2015, 08:47 PM
  2. So let me get this straight.....
    By ccflee1 in forum Scotland
    Last Post: 01-04-2013, 07:52 PM
  3. Question Straight through exhaust? tdi?
    By clarksbm in forum Bora - 1998 - 2005
    Last Post: 09-09-2012, 09:02 PM
  4. will RS6 wheels fit straight on a '99 A4?
    By greedyguts02 in forum Wheels and Tyres
    Last Post: 08-01-2009, 05:14 PM
  5. Fan Running straight away
    By kevybhoy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2007, 10:21 PM
