Thread: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
Results 1 to 10 of 13
  1. Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Aug 2015
    Cambridgeshire
    Has anyone removed and cleaned their EGR valve?
    It's something I did every 30-40k miles on my A4 B8
    I'm assuming it has never been done on my A5, and at 60k it's likely to be in need of a clean soon.
  2. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    131 Post(s)
    1976 Post(s)
    There are two very different systems depending on engine code but they both soot up and it is a filthy job to clean out as you will know.
  3. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Aug 2015
    Cambridgeshire
    Hi Crasher,
    The logbook suggests it's the DETA engine. I'm pretty sure it's this part, but unfortunately not as accessible as the A4 B8.
    It looks like it'll be easier to remove from underneath the car, along with a few other components?
  4. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Aug 2015
    Cambridgeshire
    So I jacked the car up and removed the 20 or so screws holding up the engine undertray, and access wasn't any easier.
    My mate owns a garage, so I could use his ramp.
    There's a lot to remove from the top, and given this is purely preventative, I'm considering the "remove a pipe and spray cleaner" method. However, knowing how tough this stuff is to clean, I'm not overly optimistic.
    Can anyone recommend a product for this? Where does all the crap go, into the CAT?
  5. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Aug 2015
    Cambridgeshire
    I've done a bit more research on this and it appears the EGR cooler is more/as susceptible to clogging, but it cannot be cleaned as reliably as the EGR valve.
    Removal also requires draining of the coolant, and there are some plastic pipes susceptible to cracking if not careful.
    Decided to call the VAG specialist I've been taking our cars to for about 8 years today, and they said it's a 6 hour job totaling ~£900 with a new EGR valve and cooler assembly.
    Definitely not on the same level as the A4. That's fine - things change. Might leave this one to the pros 🤔
  6. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    131 Post(s)
    1976 Post(s)
    You also have to remove the exhaust downpipe which means removing the EGT sensor and this is prone the galling its thread
  7. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Aug 2015
    Cambridgeshire
    Just to avoid causing any confusion, the photo I uploaded in post #3 is not the EGR valve.
    The EGR valve and cooler are located on the lower left rear side of the engine. The side of the valve can been seen looking through the gap here:
    Foy anyone wanting to attempt this as a DIY, I can confirm it a 6+ hour job, and requires a great deal of patience.
  8. Question Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Oct 2023
    DL12 8XQ
    Hi guys, My B9 A5 2.0 TDI has just been at audi and their quoting 1.8k for a new EGR cooler to be fitted which sounds like utter ********* to me since the part is like £400 and also doesnt nessecerally need to be replaced. Can this part be cleaned using these EGR cleaner sprays ? Diesel EGR Cleaner | Wynn's UK Wondering if anyone has any experience using these after getting an emissions light on their dash. Either this or will it need removing and manually cleaning ? I just dont like the idea of spraying chemicals into my intake pipe to clean something much further into the system. Any help is much appriciated !
  9. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    131 Post(s)
    1976 Post(s)
    What is the VIN?
  10. Re: Audi A5 B9 2.0 Ultra EGR Valve Cleaning
    Dec 2023
    Atlanta
    Yes, I've removed and cleaned the EGR valve on my A4 B8 every 30-40k miles. Considering my A5 is at 60k and I haven't done it yet, I'm curious if others have cleaned their A5 B9 2.0 Ultra EGR valves and if it's a similar process. Same you can observe in New Audi A5
  1. 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    By orion1210 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-06-2024, 03:21 AM
  2. Please Help How to remove EGR valve and EGR cooler from Audi A6 C7 Ultra 2014
    By Sambor11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-07-2021, 12:37 PM
  3. EGR valve Audi A6 C7 2.0 tdi 190 ps Ultra
    Last Post: 28-01-2018, 07:34 PM
  4. Replies: 0
    Last Post: 03-12-2013, 11:51 PM
  5. Question Audi A4 3.0tdi EGR valve cleaning
    By mongs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-06-2012, 07:47 PM
