Thread: Tiguan - no access to 53 Parking Brake
  1. Tiguan - no access to 53 Parking Brake
    Aug 2010
    kigsbridge, devon
    Hi All
    I hope i'm not being super thick here, I have done the rear pads on a passat before with nos issues. Went to help a mate this evening to change discs and pads on his 2017 (5N) tiguan and i get no response from address 53 Parking brake. I've done the following:
    Hooked up a battery charger
    Cycled EPB on then off
    Scanned all modules and cleared an ABS fault (tyre pressure)
    However, I get no response from controller when accessing address 53
    My VCDS has literally just had an update, might there be a bug?
    Apreciate any help or advice.
    You don't know how it works until you take it apart!
  2. Re: Tiguan - no access to 53 Parking Brake
    1837 Post(s)
    The calipers are controlled by the ABS ECU, the function is in the menu.
  3. Re: Tiguan - no access to 53 Parking Brake
    Aug 2010
    kigsbridge, devon
    Thanks Crasher, that was easy! How It should be now I guess.
    Appreciated 👍
  1. Question 2018 VW Tiguan 5N Access to Body Control Module.
    By Tom Baxter in forum Tiguan
    Last Post: 11-11-2019, 05:33 PM
  2. Replies: 1
    Last Post: 07-01-2016, 09:08 PM
  3. Front parking sensor access
    By hanny77 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-11-2015, 07:29 PM
  4. Security access for parking brake
    By Plife in forum VCDS - Help Requests
    Last Post: 04-08-2013, 11:54 AM
  5. How do i access the brake light switch ???????
    By PassSPORT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2010, 08:06 PM
