Thread: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
Results 1 to 9 of 9
  1. A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    Jul 2018
    Liverpool, UK
    I wonder if anyone can help with this issue rendering my A6 Allroad undriveable? Last week I was driving to work and the yellow air suspension light came on suddenly - suspension had been woring fine until then, if perhaps a little slow. It had sat perfectly level all round and never dropped overnight or anything like that. Within a couple of minutes all the suspension had dropped completely to the ground. I drove the couple of miles home, very slowly, and took out the compressor to check it over. It wasn't running when the car was switched on but, after removal and connection up to a power supply, the motor ran fine. I've decided to replace with a new one anyway which I have fitted tonight.
    No joy - the new compressor doesn't run and, when I tested the power supply from the car with a multimeter, there was no voltage.
    I thought that maybe the 40A fuse or relay was at fault and have searched out several that I thought may control the compressor. There seem to be a lot of different possible locations - the relay (643) in the plenum chamber under the bonnet (driver's side, RHD car) and fuse there seem fine, as do the ones in the driver's footwell (again 643). I swappped each of these over in turn to see if that made a difference. There are another couple of relays with a 370 number that I haven't swapped over to test yet. I'm not really sure whether any of these are the right one really - all advice welcome!
    Any thoughts please? It's a 2008 C6 model, 3.0TDI that has been ultra reliable up till now.
    Thanks, Owen
  2. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    135 Post(s)
    2036 Post(s)
    Any fault codes?
  3. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    Jul 2018
    Liverpool, UK
    Haven’t checked yet as don’t have a Windows laptop for the software - nothing showing up on a basic reader. Will hopefully be able to check by the weekend. Will the compressor fail to operate if there are fault codes that haven’t been cleared?
  4. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    135 Post(s)
    2036 Post(s)
    It will only shut off if it overheats.
  5. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    Jul 2018
    Liverpool, UK
    Ok, thanks. I disconnected the new compressor and connected it directly to 12v to check it’s ok, and it runs fine. No lift to the suspension though, and still doesn’t run when plugged in to the car.
  6. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    135 Post(s)
    2036 Post(s)
    I need to study the wiring diagram but my offline elsa crashed and I am waiting for a new version; you need to do a fault code read.
  7. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    Jul 2018
    Liverpool, UK
    Right, progress I think. The first scan showed up these codes:
    5 Faults Found:
    00775 - Level Control System Sensor; Rear Right (G77)
    008 - Implausible Signal - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 253030 km
    Time Indication: 0
    Date: 2022.03.18
    Time: 08:15:27
    01768 - Sensor for Vehicle Leveling; Right; Supply Voltage
    002 - Lower Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 190
    Mileage: 253030 km
    Time Indication: 0
    Date: 2022.03.18
    Time: 08:15:44
    02646 - Plausibility of Level Control System
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 230
    Mileage: 253032 km
    Time Indication: 0
    Date: 2022.03.18
    Time: 14:46:59
    01397 - Venting Solenoid for Level Control (N111)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 230
    Mileage: 253039 km
    Time Indication: 0
    Date: 2022.03.18
    Time: 17:53:59
    01399 - Relay for Level-Control Compressor (J403)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 230
    Time Indication: 0
    After clearing all these, the compressor jumped into life and the car started to lift. Height settings now on again instead of greyed out and the car stays up. The yellow warning light is still on, however, and a new scan brings up this fault:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 253039 km
    Time Indication: 0
    Date: 2022.03.25
    Time: 18:24:45
    So, do you think that could have been the problem all along? And hopefully a simple fix of changing that sensor? If I can find where it is, that is! Any thoughts? It seems strange that the whole car dropped suddenly at al corners when there were no perceivable leaks from anywhere before that point.
  8. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    May 2024
    Auckland New Zealand
    Hi anybody and everybody.
    I NEED HELP LIKE YESTERDAY.
    Firstly, My name's Samantha and I'm in New Zealand.
    In advance id like to say thanks for any advice , this is my first time asking anything /anywhere, so please excuse if I'm not correct in my formation
    And I'm not too educated in the euro department, anyway....
    I recently (3Months ago) purchased my
    2005 AUDI A6
    AVANT S LINE V8 4.2L / Station Wagon, from a social media marketplace advert, upon purchasing the previous owner *no longer contactable* advised me that the radio, navigation system, DVD etc, etc,, wasn't working and was unsure the cause of it, and he hadn't bothered to try get it going as he liked the quiet while driving.;
    Apart from that he noted that when vehicle is parked up it will automatically lower itself, but that once started and let to warm up, that the car would self adjust the suspension and everything is back to 'normal.
    //Remember I'm not educated with this particular vehicle, so I just took his word for it.
    ==== Since owning it and driving (the driving has been wonderful, no issues their, but I've learnt that the centre controls that he said didn't work..... Well, that is pretty much the brains of the car, this being the *
    ***"(MMI Control Unit )"***
    And so that's as far as my knowledge goes for any relating specifications or functioning, I don't know what exactly it is ment to do, but when I start the car the screen turns on for about 4seconds but turns off and no response to any button pushing on the centre control unit, but it will turn on and display the reversing camera, while ofcourse having it in 'R'.
    The passenger glove compartment is filled with DVD player, cd disc player and a another unit that I'm not too sure about.
    I have located in the boot luggage passenger side, another 4/5 units that look maybe like the amp's etc....
    I have quickly checked all 3 fuse box locations and those are even a mess, but all assigned fused that should be for the MMI CONTROL/ RADIO / NAVIGATION / TELEPHONE, ETC are what appears to be fine....
  9. Re: A6 Allroad 2008 All Suspension Dropped Compressor Not Running
    135 Post(s)
    2036 Post(s)
    You need a skilled Audi technician with at least the diagnostic system VCDS but preferably the dealer system ODIS and to be in possession of all the relevant data which can be downloaded from Audi erWin. I am such a tech with 42 years experience and have the systems plus info and even then with it here in the UK where new and used parts are easy to find, it is not a task I would take lightly.
  1. A6 Allroad front suspension dropped, one side only
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-05-2021, 01:56 PM
  2. 2008 A6 Allroad - suspension dropped on one wheel and lights flashing
    By jr92897 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-09-2019, 06:15 AM
  3. allroad suspension compressor and vag-com?
    By Grizgut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-10-2010, 07:41 AM
  4. Allroad Suspension Compressor
    By Boothyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2010, 08:50 AM
  5. The air suspension compressor is almost constantly running.
    By jansko in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-03-2008, 09:00 AM
