Thread: Brake fluid change advice
  1. Brake fluid change advice
    Mar 2021
    Ripon
    7 Post(s)
    I need to change the brake fluid on my 2018 2.0 TDI 150 Manual with a hydraulic clutch.
    Do I need to bleed the clutch as well? If so, before or after the calipers? Is there a bleed nipple on the transmission? Is this accessed by removing the air box? Do I need a pressure bleed kit to bleed the clutch? I have been meaning to buy one for a while. I was this thinking about the Sealey VS820.
    Has anyone carried on this procedure recently and are they able to answer any of the above questions?
  2. Re: Brake fluid change advice
    1841 Post(s)
    Yes bleeding the clutch is a good idea, there is a "nipple", we have an SP electric pressure bleeder, pumping the pedal can upset the seals occasionally.
  3. Re: Brake fluid change advice
    Mar 2021
    Ripon
    7 Post(s)
    Thanks for that. Does it matter in which order the clutch and brakes are bled?
  4. Re: Brake fluid change advice
    1841 Post(s)
    To some people yes, I do front, rear and then clutch.
  1. Question Brake fluid Change DOT 4 or?
    By Novica in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-02-2016, 07:26 PM
  2. should i change the brake fluid ?
    By vwnige in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2012, 05:53 PM
  3. Brake Fluid Change
    By black999 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-06-2011, 01:54 PM
  4. brake fluid change
    By shuggie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-07-2008, 04:51 PM
  5. Brake Fluid Change
    By grahamcoutts in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-01-2008, 03:52 PM
