Thread: Codes showing temp sensor issue
Results 1 to 10 of 16
  1. Post Codes showing temp sensor issue
    Wales
    Hi , I didn't know how to edit previous thread title so here's a new thread .
    Codes are showing as "temperature sensor 2 fault" . I firstly assumed it was possible water infiltration near the ecu as the code came and went several times but this apparently is not the cause . The fault is also raising blocked radiator fan or obstruction and both are free so I assume the temp sensor malfunction is causing a knock on effect here .
    There are 2 coolant temp sensors , 1 is egr side , I think the other is near the thermostat , not sure , but what will be the most likely of the 2 sensors causing radiator fan blocked or obstructed?
  2. Re: Codes showing temp sensor issue
    Wales
    I changed BOTH coolant temp sensors and the engine light reappeared after 2 days so Then I changed the 2 pin connector plug that feeds sensor 2 as there was significant corrosion inside the terminals . Light went out and has now come back on again codes read same as before . Coolant temperature sensor two reading too high . Radiator fans blocked or restricted . I am just at an end to figure the cause here , fans spin freely and the light resets itself and comes back on numerous times. Does anyone have any ideas please?
  3. Re: Codes showing temp sensor issue
    Mar 2010
    Derry ireland
    60 Post(s)
    The cooling fan (fans) has to be controlled so that allows the engine to maintain a constant temperature. these fans must have a 5v feed with in the spec 4.48-5.2 and is soley worked via ecu via coolant temp sensor. It would not go amiss to check wiring from the 2 sensors to the ecu pin nos ??? can you post up eng code
  4. Re: Codes showing temp sensor issue
    Wales
    Cffb
  5. Re: Codes showing temp sensor issue
    1837 Post(s)
    Can you post a full car code read including the VIN.
  6. Re: Codes showing temp sensor issue
    Wales
    Dont have codes on me but auxillary water pump ...coolant temp sensor 2 high...vin: WVWZZZ3CZBE354851 auxillary water pump has been a fault for several years , could this also make coolant temp sensor show up?
  7. Re: Codes showing temp sensor issue
    Wales
    Found a previous auxillary pump code that flagged possibly still same: P261A00 coolant pump 2 open circuit. Code possibly P2182 for secondary coolant temp sensor reading too high. The car drives ok but engine light is of concern ofc. Both coolant sensors have been replaced OE parts. Engine light constantly lighting and then resetting for few days.
  8. Re: Codes showing temp sensor issue
    1837 Post(s)
    Have you replaced the elctic water pump on the front of the engine? Only use genuine and you need to now if it has Pierburg or BUEHLER fitted.
  9. Re: Codes showing temp sensor issue
    Wales
    I actually have one on my passenger seat it was taken of a workmates same engine last night, he seized his when fan belt shredded around bottom pulley. Would this flag the temp sensor code as the auxiliary pump has been open circuit several years.
  10. Re: Codes showing temp sensor issue
    Wales
    I just spoke to a mechanic and hes going to run diagnostics to all sensors to measure voltages, it maybe even dirty connector in that loom. As the auxillary pump has been open circuit for several years, Im thinking it unlikely to flag the sensor issue.
  1. Please Help 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
    By Bro4eva in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-12-2018, 05:50 PM
  2. Can a lambda sensor be faulty with no codes showing?
    By flat4fanatic in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2017, 08:29 PM
  3. Outside temp showing crazy figures - 40 degrees?
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-07-2014, 02:59 PM
  4. Temp Guage Showing Low Temp
    By Mad mike in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-11-2011, 03:25 AM
  5. P118 coolant temp sensor issue/s
    By bowdeenio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-11-2010, 02:23 PM
