Thread: Codes showing temp sensor issue
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Codes showing temp sensor issue
    Wales
    Forgot to mention radiator fans blocked or restricted also came up as one of the fault codes. Atm the engine light is off.
  2. Re: Codes showing temp sensor issue
    1840 Post(s)
    We see that code a lot and we fit a new fan pack
  3. Re: Codes showing temp sensor issue
    Wales
    Thank You Crasher I was thinking the same thing .
  4. Re: Codes showing temp sensor issue
    Wales
    Car just passed mot and the engine light stayed out for almost a week even after long journeys , however upon starting the car from cold last night , the engine light came back on , there has to be a wiring or connection issue , it cant be faulty coolant temp sensors (both changed OE) also the connector plug changed on sensor 2 , the one with the code error . Just puzzled why the same error code keeps appearing and the engine light is on one day and off another . The car as I said previously is driving ok and the engine temp is normal . I had two different mechanics scan the car before mot test and nothing was in the system memory regarding these faults , after being cleared . If i go down the road of new fans , and it doesnt alter anything it will end up costly so I will try checking the wiring from ecu to both coolant temp sensors starting with sensor 2 as that is the error code fault.
  5. Re: Codes showing temp sensor issue
    1840 Post(s)
    Remind me of the fault code?
  6. Re: Codes showing temp sensor issue
    Wales
    Just got back from the garage , only error showing now was auxiliary water pump open circuit , I have spare one but not sure what model is on my car without getting the drip tray off . I also have the bracket with it so it shouldn't matter if its Buehler or Pierburg in that case as VW just told me they have different fixing brackets thats all . I dont know why though the engine light is showing after that auxiliary pump has been faulty for several years . So the nest job when I can do it is change that pump .)
  1. Please Help 5 fault codes showing, fuel gauge displays empty, 00438 - fuel supply sensor 2 (G169)
    By Bro4eva in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-12-2018, 05:50 PM
  2. Can a lambda sensor be faulty with no codes showing?
    By flat4fanatic in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2017, 08:29 PM
  3. Outside temp showing crazy figures - 40 degrees?
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-07-2014, 02:59 PM
  4. Temp Guage Showing Low Temp
    By Mad mike in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-11-2011, 03:25 AM
  5. P118 coolant temp sensor issue/s
    By bowdeenio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-11-2010, 02:23 PM
