Thread: Handbrake issue
Results 1 to 8 of 8
  1. Handbrake issue
    Liverpool
    11 Post(s)
    I think anyway, 2003 A4 cab, moved the car earlier then set off later for work, when i pulled away the car creaked as though the handbrake was still on, or partly on. the handbrake itself as fully down. Drove to work OK (10 miles), pulled the handbrake up to get out and only seemed to go up about 1/3 the height it usually goes up.
    Car doesnt feel like it sticking, or stuck on, but i cant be sure. Any ideas guys? Or anything I can check?
  2. Re: Handbrake issue
    1840 Post(s)
    Any of the wheels showing signs of excessive radiated heat? Don't touch a disc or wheel if you think it may be hot.
  3. Re: Handbrake issue
    Liverpool
    11 Post(s)
    Hi Crasher
    just laid under it and sprayed up the handbrake mechanism on the rear callipers, put handbrake on several times and now it’s coming up to normal height. The rear wheels spin a little (got nothing to compare it to). Rear R/H side calliper looks as though it’s been hot, slightly whitish colouring?
  4. Re: Handbrake issue
    Liverpool
    11 Post(s)
    Sorry forgot to say, no sign of heat transfer to either alloy
  5. Re: Handbrake issue
    1840 Post(s)
    Sounds like a failing caliper handbrake mech.
  6. Re: Handbrake issue
    Liverpool
    11 Post(s)
    Thanks Crasher - it seems to of freed up a bit, but if I have more issues I’m guessing replace the whole calliper?
  7. Re: Handbrake issue
    1840 Post(s)
    Yes, if we have the lead time we order TRW new units (or exchange if that is all they offer) but they take about a week to arrive.
  8. Re: Handbrake issue
    Dec 2008
    I had a damaged cable sheath a while back, corrosion then caused the cable to resist the force of the springs that pulls caliper arm back to position slightly different symptoms but no harm in looking at that cable too.
    0 2 0
  1. Another A6 Electric handbrake issue
    By crazydiamond70 in forum VCDS - Help Requests
    Last Post: 16-05-2021, 09:58 PM
  2. Question Another A6 Electric handbrake issue
    By crazydiamond70 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-04-2021, 12:12 PM
  3. 09 cc handbrake issue
    By mactac1701 in forum Passat CC
    Last Post: 01-09-2010, 08:25 PM
  4. Handbrake issue
    By Bigdogcasa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-05-2010, 05:27 PM
  5. Handbrake Issue with positive result
    By forge197 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2009, 08:43 PM
