Thread: Clutch
  1. Re: Clutch
    2019 Post(s)
    Message me the reg or post the VIN.
  2. Re: Clutch
    2019 Post(s)
    You have the 02Q transmission with the internal concentric release bearing. We have been fighting one of these in an Alhambra 2 for a couple of weeks now. It presented with a pedal that hit the floor but pumped back up with a number of hand operations which can be master cylinder or release bearing. Obviously the MC is cheaper so we did that first and it worked for a few weeks and did it again so we did the full clutch. After a few weeks it did it again but now had some resistance right at the bottom and it immediately came back as the pedal was pulled up and we think this was the plastic in-line vibration damper so we fitted a new one Friday for me to test over this weekend. Getting in to go home it stuck down again but this time it was the very poorly fitting floor matt just being in the right spot to lock it down so that went in the passengers footwell and it has been fine yesterday and this morning.
  3. Re: Clutch
    Feb 2022
    Wolverhampton
    Ok thanks I don't think I bring myself to spend any money on this car I'd probably do it if it was just the master cylinder. Don't trust with not being able to select gears.
  1. Please Help Audi A3 2.0TDi hydraulic clutch - free play (top of clutch)
    By RavP in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-01-2018, 03:13 AM
  2. Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    By uncleron in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2013, 08:37 PM
  3. Replies: 5
    Last Post: 08-04-2013, 09:23 PM
  4. Please Help Replaced flywheel and clutch kit......but still makes that clunk noise from the clutch :(
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-06-2011, 05:04 PM
  5. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
