Thread: Low speed judder
Results 1 to 10 of 14
  1. Low speed judder
    Dec 2008
    Been a while since I posted here. I have owned a B8 A4 allroad, 3ltre with an S Tronic box, for the past 2 years. 140000 miles. Drives pretty well, but when braking and coming to a slow stop, the car seems to bounce forward before stopping. Not all the time and not when braking firmly. The garage can't find anything that might be the cause.
    Anyone experienced anything like this?
  2. Re: Low speed judder
    1840 Post(s)
    Once or a series of bounces?
  3. Re: Low speed judder
    Dec 2008
    Just the once. Feels almost like the brake comes off then on again. Garage say the calipers are fine.
  4. Re: Low speed judder
    1840 Post(s)
    Interesting, suggests to me a ball joint, the lower main one is prone to failure and very hard to tease movement out of in the air.
  5. Re: Low speed judder
    Dec 2008
    I mentioned that to the garage, they are going to check it out. They are also going to look at the driveshaft carrier bearing.
    Thanks for that.
  6. Re: Low speed judder
    Mar 2022
    Sweden
    I have the same issue, mine is a 2013 B8.5 with a multitronic gearbox. But I have a series of bounces when I come to a slow stop.
    As OP said, it feels like the breaks come on and off.
    Could it be the same cause? I was either way planning to do a complete suspension overhaul.
  7. Re: Low speed judder
    1840 Post(s)
    Possibly a warped or corroded disc
  8. Re: Low speed judder
    Dec 2008
    Restarting an old thread. The garage found a lot of play in the passenger side front driveshaft and attempted to change the bearing, but are now saying that the gearbox is at fault and needs replaced. Anyone any thoughts on this?
  9. Re: Low speed judder
    1840 Post(s)
    What is the VIN?
  10. Re: Low speed judder
    Dec 2008
    Vin is wauzzz8k3aa108662
  1. 7 Speed DSG Judder
    By garyrm in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-03-2023, 12:33 PM
  2. 7 Speed DSG Judder
    By garyrm in forum Octavia
    Last Post: 31-01-2011, 02:00 PM
  3. Question Steering Judder at low speed normal ??
    By Chucky666UK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-10-2010, 02:28 PM
  4. vw golf gt tdi Judder at high speed!Help!
    By Abs456 in forum Golf MK5 - 2004 - 2009
    Last Post: 11-06-2009, 10:48 PM
  5. Cold speed judder
    By v6dub in forum Golf MK4 - 1999 - 2004
    Last Post: 19-01-2008, 12:24 PM
