Thread: Drivers door control only operates osr window up and down and nsr window down
  1. Drivers door control only operates osr window up and down and nsr window down
    Mar 2022
    PA102NH
    Hi guys, just bought b7 o7 a4 2.0 tdi s line quattro avant. Drivers window mech can be heard working from the switch but window does not work. Nsf does operate from nsf switch. Nsr goes down via drivers switch but not up. Works from door switch. Osr window works both via drivers and door switch 🤷*♂️. Also 12v outlet in front (which I've just replaced with new) doesn't work. All suggestions appreciated. I'm a newbie to audi but 5 previous VAG. Please be kind 😂
  2. Re: Drivers door control only operates osr window up and down and nsr window down
    1840 Post(s)
    the drivers window cable will be broken and the glass probably held up with a piece of wood, it is very common. For the rest, start with a VCDS code read.
  3. Re: Drivers door control only operates osr window up and down and nsr window down
    Mar 2022
    PA102NH
    Thanks so much, absolutely no codes active unfortunately but my b
    Next action was to take the door card off anyway.
    I also stand with Ukraine ���� FU Putin
    1 1 0
  1. MK6 3 door drivers window
    By Njduk in forum Golf MK6 - 2009 - 2013
    Last Post: 09-10-2018, 02:17 PM
  2. Only drivers window operates from master controls
    By pricey2k9 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2012, 11:51 PM
  3. Wanted ! Manual window regulator for 3 door drivers door!
    By m0mjt in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2010, 10:56 AM
  4. Question Replacement drivers window control unit
    By ally0000 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-08-2009, 11:37 AM
  5. Drivers door window
    By passman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2008, 08:37 PM
