Thread: 1.6 AKL hunting idle/does not rev up
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: 1.6 AKL hunting idle/does not rev up
    Mar 2022
    United Kingdom
    Any, even the tiniest, air leak into the intake system after the AMM can cause a lot of trouble
    I replaced the oil cap breather and intake pipe and it still starts running rough when it gets up to running temp. Really bad hunting.
    Fault code with air mass sensor short/open circuit is still popping up.
    I am now lost.
    Could the coolant temp sensor be a issue if there is no fault code?
    Where do I look next
  2. Re: 1.6 AKL hunting idle/does not rev up
    Mar 2022
    United Kingdom
    Still also got the issue where theres no piwer, It has its moments, it runs lovely, revs up nice and can be driven but then ill stop and go to pull away and it goes to stall because it doesnt have enough power to even move.
  3. Re: 1.6 AKL hunting idle/does not rev up
    1840 Post(s)
    What make of AMM did you fit?
  4. Re: 1.6 AKL hunting idle/does not rev up
    Mar 2010
    Derry ireland
    60 Post(s)
    Why did you dismiss the fault code. Air mass sensor short/ open circuit did you not realize the fault code tells 1 its not being powered up so why fit new unit.
  5. Re: 1.6 AKL hunting idle/does not rev up
    Mar 2022
    United Kingdom
    As stated last week, i saw AMM fault code and Crasher told me its likely due to it being unplugged whilst engine is running (which i stupidly did) but after revisiting the car yesterday and clearing the codes it does keep popping up so it must been there before, not just unplugging the AMM.
    Anyway, Crasher, I checked out the AMM and tested power to it with a multimeter, I have my 5v going to it. The AMM doesn't have a brand on it, or a part number. It looks like a cheap generic part.
    I also want to say again that the exhaust is blowing from the exhaust manifold where the downpipe joins, from the gasket.
  6. Re: 1.6 AKL hunting idle/does not rev up
    Mar 2022
    United Kingdom
    I also had battery voltage going to the AMM too
  7. Re: 1.6 AKL hunting idle/does not rev up
    #17
    1840 Post(s)
    Get a new genuine VW AMM, part number 06A 906 461 B, at £337.51 these are stupid money but it is the only way you can be 100% sure what you are fitting is correct.
  8. Re: 1.6 AKL hunting idle/does not rev up
    #18
    Mar 2022
    United Kingdom
    Yeah thats gonna hurt the wallet! Expensive part ain't it but you are right. Buy cheap buy twice i always say
  1. Please Help Hunting Idle
    By Mk2Phil in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-09-2012, 10:46 PM
  2. 1.8T Hunting idle
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-11-2011, 10:54 PM
  3. Hunting Idle
    By trance in forum Golf MK4 - 1999 - 2004
    Last Post: 02-11-2010, 01:36 AM
  4. Question Hunting when Idle
    By vwredgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 29-03-2009, 06:26 PM
  5. 97 A4 1.8 Hunting at idle
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 11:05 AM
