Thread: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
Results 1 to 10 of 19
  1. 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Mar 2022
    Nottinghamshire
    Hi all, I'm having a problem with my 2006 A6 3.0, recently (within the last few weeks) the battery is occasionally draining flat overnight and needing to be jump started the following morning, some mornings it's fine some it's dead. The battery is only a month or so old and I've had it tested and been told it's fine. The battery health meter on the MMI shows 10% and if I turn the key in the ignition but don't start the engine I get the warning beep saying 'Battery Low'. I've tried coding the battery with OBDEleven which shows the health at 100% on the MMI but doesn't change anything. With the engine running, the heated seats and rear window defroster will only stay on for about 3-4 minutes before turning themselves off. Any help solving this would be greatly appreciated, thanks!
  2. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Mar 2021
    wigan
    if i was you i would contact pawel tylkowski on facebook lucky for you hes in newark
  3. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Jul 2008
    Lisburn
    15 Post(s)
    sounds like it could be your BCM - remove the connector and check for corrosion.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Mar 2022
    Nottinghamshire
    Quote Originally Posted by swwalker View Post
    Thanks for your reply, where is the BCM located? I'll have a look at it when I finish work.
  5. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Jul 2008
    Lisburn
    15 Post(s)
    in the boot beside the battery follow the negative wire off the battery it goes into it. there will be a small 10 pin or so connector. carefully remove it to see if there is any nasty green stuff.
    Stewart
  6. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Mar 2022
    Nottinghamshire
    I've taken the connector off and it looks like there is some stuff on the pins/connector
    Screenshot-20220315-155902 — ImgBB
  7. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Jul 2008
    Lisburn
    15 Post(s)
    that will not help, get some contact cleaner in there and dielectric grease - mine was like this giving low battery errors i was able to clean it a few times then a pin fell off!!
    Stewart
  8. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Mar 2022
    Nottinghamshire
    Thanks I'll give it a go. One of the pins looks like it's about to fall off, if it does fall off is replacing the module as simple as buying another and replacing or is there coding to do? Thanks again
  9. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    Jul 2008
    Lisburn
    15 Post(s)
    I got mine from ECU 2 you off ebay, it came with 3 year warranty and a sticker on - seems silly but if he is going to put his name on it he is going to stand by it - which he has.
    I got a few errors of charge current and i asked him if he had any advice - first thing he offered was a replacement. But i then checked it over and i don't think i got all the green stuff cleaned out of the connector so i just cleaned it last night.
    Some are programmable some are not mine was not, ecu 2 you did say no programming required, and the option is not there in OBDeleven. There was as a guy with an 06 in a local group, NIAOC, who was able to program his with obdeleven.
    Stewart
  10. Re: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
    1836 Post(s)
    Yuasa 5000 battery by any chance?
  1. Please Help Windows half way down overnight and more electrical 'gremlins' - ideas please!
    By Swoot in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-02-2016, 01:06 PM
  2. Discharging battery fixed. I think.
    By msh in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-02-2013, 07:06 PM
  3. iPod battery discharging quickly
    By Chris-h in forum Golf MK6 - 2009 - 2013
    Last Post: 08-04-2011, 09:53 AM
  4. Please Help Battery discharging
    By rushma in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2009, 12:15 PM
  5. Please Help Central Locking / battery discharging
    By tipptopp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2008, 12:20 PM
