Thread: Power windows Passat 2007
  1. Power windows Passat 2007
    Dec 2020
    Sweden
    Both my front power windows stopped working this winter and i do not have any fault codes...
    When I connect the car to Odis, and do a test cycle on the windows, all the buttons work as they should but when it comes to the window motor it say "Inactive".
    Same test works great on the rear windows.
    I have tested to change the power windows from a another car but still get the same message "inactive" when doing the test.
    Even tested the original power windows on the bench with 12v and it works fine...
    Is it some reset procedure to get the windows working again?
    I know when i changed the electric handbrake I need to do a battery reset, pressing the brake for 30sec then the parkingbrake for 10 sec to get the parking module to reset.
    Or do I need to change the comfort module and if so, how do I do that?
    Regards
    /Lundgren
  2. Re: Power windows Passat 2007
    1840 Post(s)
    I have seen a similar problem after a new body control module was fitted, the door controlera nd the ABS pump decided to recode themselves so as you have ODIS, carry out the SVM test on the doors to check the coding is correct.
  1. Question 2007 vw polo 1.4 petrol car's electric windows not working
    By kaijun in forum Polo - Derby - Lupo - Fox
    Last Post: 04-03-2022, 05:20 PM
  2. Please Help Polo 2007 9N3 - Central Locking & Electric Windows - Problem
    By aperson in forum Polo - Derby - Lupo - Fox
    Last Post: 07-06-2021, 12:10 PM
  3. Question 2007 Passat power steering "notchy"
    By jmurray01 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-10-2018, 11:06 PM
  4. Replies: 4
    Last Post: 20-09-2015, 09:09 AM
  5. Heated rearside windows - 2007 A4 Avant SE
    By foxyrider in forum Chat - Anything with wheels
    Last Post: 22-01-2009, 12:35 PM
