Thread: C6 2007 - MMI dead
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: C6 2007 - MMI dead
    1840 Post(s)
    It is shown as being behind the glovebox and will have one of these part numbers
    4F0910729_/_X
    4F0910729Q/QX
    4F0910730D/DX
    4F0910730B
    4F0910731_/_X
    4F091073F/FX
    4F0910731D/DX
    4F0910731L/LX
    4F0910731J/JX
    4F0910731R/RX
    4F0910732A/AX
    4F0910732D
    All replaced by 4F0 910 732 HX
  2. Re: C6 2007 - MMI dead
    Mar 2022
    Leicestershire
    Fantastic, got it - thank you. It was more tucked away than I expected.
    I know that this is a common issue. Do people tend to replace them with 4F0 910 732 HX?
    I’ve looked online and direct replacements seem to be plentiful and cheap. I understand that I meed to get the same SW prefix and complications with component protection.
    I can’t seem to find anyone who sells refurbished/warrantied items, so I’m guessing it might be a bit of a lottery now to replace it.
  3. Re: C6 2007 - MMI dead
    Mar 2022
    Leicestershire
    Ok, so I’ve bought VCDS and a ross-tech cable.
    Plugging it in and doing a scan of the optical bus diagnostics, I get faults for:
    19-CAN gateway
    07-Control head
    0E-Media Player
    77-Telephone
    47-Sound System
    56-Radio
    37-Navigation
    When I go into each of the controllers to retrieve the fault code, I just get an error message saying ‘no response from controller’
    Any ideas?
  4. Re: C6 2007 - MMI dead
    1840 Post(s)
    Could you do a full scan and post it?
  5. Re: C6 2007 - MMI dead
    Mar 2022
    Leicestershire
    Thanks for your ongoing help Crasher, I really appreciate it.
    I've bought VCDS and a ross-tech cable on a netbook which won't connect to the internet - no idea why! So, I'm typing it out
    I've just done a summary - but none of the codes appeared to be recent and I don't have any MIL's on currently either. Do let me know if you want any of the freeze frame or part number info for any of the codes or modules.
    Thanks again!
    Code:
    01 - Engine -- Status: Malfunction 0010
    02 - Auto Trans -- Status: OK 0000
    03 - ABS Brake -- Status: Malfunction 0010
    05 - Acc/Start Auth. -- Status: OK 0000
    07 - Control Head -- Status: Cannot be reached 1100
    08 - Auto HVAC -- Status: OK 0000
    09 - Cent. Elect. -- Status: Malfunction 0010
    0E - Media Player 1 -- Status: Cannot be reached 1100
    15 - Airbags -- Status: Malfunction 0010
    16 - Steering Wheel -- Status: Malfunction 0010
    17 - Instruments -- Status: OK 0000
    19 - CAN Gateway -- Status: Malfunction 0010
    37 - Navigations -- Status: Cannot be reached 1100
    42 - Door Elect, Driver -- Status: OK 0000
    46 - Central Conv. -- Status: Malfunction 0010
    47 - Sound System -- Status: Cannot be reached 1100
    4F - Centr. Electr. II -- Status: Malfunction 0010
    52 - Door Elect, Pass. -- Status: OK 0000
    53 - Parking Brake -- Status: Malfunction 0010
    56 - Radio -- Status: Cannot be reached 1100
    61 - Battery Regul. -- Status: Malfunction 0010
    62 - Door, Rear Left -- Status: OK 0000
    72 - Door, Rear Right -- Status: OK 0000
    76 - Park Assist -- Status: OK 0000
    Address 01: Engine
    2 Faults Found:
    005491 - Left Engine Mount Solenoid Valve (N144)
                       P1573 - 001 - Open Circuit
    005715 - Please check DTC Memory of ABS Controller
                       P1653 - 002 - Intermittent
    Address 03: ABS Brakes
    2 Faults Found:
    01826 - Sensor for steering angle (g85): Supply Voltage Terminal 30
    000 - - -Intermittent
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory - Intermittent
    Address 07: Control Head
    Cannot be reached
    Address 09: Cent. Elect
    1 Fault Found:
    00924 - Relay for headlamp cleaning System (J39)
    0014 - Defective - Intermittent
    Address 0E: Media Player 1
    Cannot be reached
    Address 15: Airbags
    3 Faults Found:
    02095 - Component Protection Active
                 000 - - - Intermittent - MIL ON
    01228 - Airbag Cut Off Switch for Passenger Side (E224)
                010 - Open or short to Plus - Intermittent - MIL ON
    02756 - Redundant signal path of Airbag cut off switch - front passenger side (E224)
    Address 16: Steering wheel
    2 Faults Found:
    00446 - Function Limitation due to under-voltage
                     002 - Lower limit exceeded - Intermittent
    00532 - Supply Voltage B+
    Address 19: CAN Gateway
    00384 - Optical Databus
                  011 - Open Circuit
                  Freeze Frame:
                       Fault Status: 01101011
                       Fault Priority: 5
                       Fault Frequency: 1
                       Reset Counter: 243
                       Mileage: 222557km
                       Time Indication: 0
                       Date: 2007.05.16
                       Time: 12:00:13
    Address 37: Navigation
    Cannot be reached
    Address 46: Central Conv.
    1 Fault Found
    01565 - Luggage Compartment Light (w3)
                   009 - Open or short to ground - intermittent
    Address 4F: Centr. Electr. II
    1 Fault Found
    02752 - Glovebox Unlocking Motor (V327)
                   010 - Open or short to plus - Intermittent
    Address 53 - Parking Brake
    1 Fault Found:
    02443 - Control Head
                 012 - Electrical fault in circuit - Intermittent
    Address 56: Radio
    Cannot be reached
    Address 61: Battery Regul.
    5 Faults Found
    02272 - Quiescent Current Stage 1
    02273 - Quiescent Current Stage 2
    02276 - Quiescent Current Stage 5
    02277 - Quiescent Current Stage 6
    02256 - Quiescent Current
                 001 - Upper Limit Exceeded - Intermittent
    Address 77: Telephone
    Cannot be reached
  6. Re: C6 2007 - MMI dead
    1840 Post(s)
    Please don't cut the VIN out of the scan, it is useful and not subject to GDPR, remove the reg if you wish as that is personal data. What is the VIN. Do a full clear and run the car for a few days and do another full scan and post it in full.
  7. Re: C6 2007 - MMI dead
    #17
    Mar 2022
    Leicestershire
    Sorry - I've not intentionally cut anything out, I can't copy and paste the scan, so I've typed out the elements which I thought were useful. If there's anything particularly helpful missing, then please let me know.
    I'll do another scan in a few days and post again.
    The VIN is WAUZZZ4F58N042353
  8. Re: C6 2007 - MMI dead
    #18
    1840 Post(s)
    The way I do it is to install a generic text only virtual printer and then print the report and click print as text but you can also use the save function and open the file in Word. I realised I already had the VIN, too many irons in the fire.
  9. Re: C6 2007 - MMI dead
    #19
    Mar 2022
    Leicestershire
    Ok, so I reset my codes and I’ve driven the car around for 4 days since. All of the codes have now cleared except for two:
    005491 - Left Engine Mount Solenoid Valve (N144) P1573 - 001 - Open Circuit
    00384 - Optical Databus 011 - Open Circuit
    I am still getting “Cannot be reached” for:
    07-Control Head
    0E-Media Player
    37-Navigation
    47-Sound System
    56-Radio
    77-Telephone
    The OBD scan for that module just returns ‘Error’ for electrical and optical for all of the modules.
  10. Re: C6 2007 - MMI dead
    #20
    1840 Post(s)
    All those not reached are on the infotainment bus and the optical bus is shown as being open, I can't look at the workshop info at the moment as my copy died and I am waiting for a new one. The engine mount is easy.
  1. Dead battery or dead to earth?
    By bigman100 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-11-2019, 10:19 PM
  2. elecrical issues : -45C, ESP off, aircon unit dead, heated seats dead
    By A6quattro3.0 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-09-2018, 10:33 AM
  3. ECU dead :/
    By mrspike in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-11-2015, 01:03 PM
  4. Dead Car
    By mustrum in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-03-2009, 11:02 AM
  5. Dead 80!!!
    By sdk778 in forum 80 - 90
    Last Post: 08-05-2008, 09:12 PM
