Thread: 1996 Golf GTi Diagnostics
  1. 1996 Golf GTi Diagnostics
    Aug 2020
    Huddersfield, England
    Hi Everyone. Been a long time since I was on the forum, had a lot of illness unfortunately. Anyhow, my car has an intermittent fault whereby it cuts out after it has been running perfectly for about 2 hours on tickover. I have not been able to work on it for at least a year, but I would like to get it fixed and possibly sell it. With the correct scan tool, what level of diagnostics could I expect to be able to read? A couple of people have said that I will not be able to look at any live data and will only be able to read DTC's, is that correct?
  2. Re: 1996 Golf GTi Diagnostics
    131 Post(s)
    1976 Post(s)
    Drop the fuse box cover down and look at the main board of the relay carrier. The relays are numbered 1 to 12 top left to bottom right. At the top left 3 in, is relay 3 and this has the number 30 on top, if it is black, take it out and look for the manufacturing country and date. If it was made in the Philippines and in the mid 90's it is almost certainly faulty but German and Portuguese versions also fail. The replacements are a light tan colour and are VW part number 165 906 381. Quite worryingly I didn't have to look any of that up!
  3. Re: 1996 Golf GTi Diagnostics
    Aug 2020
    Wow Crasher! You're still out there! You have kindly advised me before on this issue. Unfortunately, all suspect relays have been replaced at least once, the ECU relay twice I think, fault still remains. Can you please set me right on the diagnostic question? Many thanks again for replying. Cheers, Bob.
  4. Re: 1996 Golf GTi Diagnostics
    131 Post(s)
    1976 Post(s)
    Quote Originally Posted by bobfrankish View Post
    I have been "out there" for a long time... The 96 AGG engine ECU has 10 blocks of live data in measuring blocks 00 but you need to interpret the, from memory VDCS does this and there is other data such as in 007 where you can see the phasing of the crank G28 and cam G40 sensors.
  5. Re: 1996 Golf GTi Diagnostics
    Aug 2020
    Thanks Crasher. I am definitely "out there"! Bad choice of phrasing I guess. Anyhow, should have mentioned, my car has the ADY engine not the AGG, and I believe it uses the Simos ECU if that helps? According to my ETOS, the ECU part code is either 037906025P or maybe 050109101A
  6. Re: 1996 Golf GTi Diagnostics
    131 Post(s)
    1976 Post(s)
    I think you will find you car is a 95 as VW stopped using the ADY in the Golf 3 on 07-95, post the VIN and I can check its DOB. The ADY and AGG are identical except they had a very slightly different piston design (replaced by the AGG version only) and the camshaft was a different profile which on the ADY caused a poor idle problem, this was cured by fitting the AGG cam (050 109 101 A) and a special ECU 037 906 025 Q to replace 037 906 025 P, I did loads of these in the late 90's.
  7. Re: 1996 Golf GTi Diagnostics
    Aug 2020
    Thanks Crasher. You certainly know you sh*t! VIN no. is WVWZZZ1HZTW016201, Engine no. ADY096933. According to V5, car first registered 02/96, so probably built in '95.
  1. MK5 Golf diagnostics
    By cdti in forum VCDS - General Questions
    Last Post: 30-07-2012, 12:37 PM
  2. Please Help Golf Mk3 1.8GL Starter Motor diagnostics advice
    By Alfonzo in forum Golf MK3 - 1993 - 1999
    Last Post: 10-04-2012, 05:40 PM
  3. Diagnostics socket on 1996 Audi A6 (V6 2.6l) UK
    By vistula in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 03-04-2009, 03:20 PM
  4. Question Key Fob Golf Mk3 TDI 1.9 1996
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 09-03-2009, 10:14 PM
  5. Using VAG-Com with 1996 MK3 Golf TDI
    By sebring in forum VCDS - General Questions
    Last Post: 21-04-2008, 06:56 PM
