Thread: Ambient temperature dash reading incorrect.
  1. Ambient temperature dash reading incorrect.
    Mar 2022
    Bedale, North Yorks
    Hi, I've had a 2.0 TDI Bluemotion DSG estate for about a month now. Yesterday I noticed the dash ambient temp readout was 16 degrees, although real outside air temp was only 8 degrees.
    Today it was initially reading about 14 degrees but went up to 16.5 degrees, even though oat was still approx 8 degrees.
    I removed the temp sensor and tested its resistance over the 2 plug terminals and it appears ok, reading about 1.7K Ohms in a cold garage. When I hold the sensor in my hand the reading goes down as expected.
    I've found a genuine replacement on the web for approx £20, but with what appears to be a good sensor, I'm wondering if there is anything else that can affect the dash reading.
    Anyone got any ideas or had the same problem?
  2. Re: Ambient temperature dash reading incorrect.
    Mar 2021
    Ripon
    7 Post(s)
    Common fault and the common solution is just to buy a new one and replace it. Mine was reading 4-5C low and the new one now shows the correct temperature. Never had this issue on any of 10 or so cars I have owned previously.
  3. Re: Ambient temperature dash reading incorrect.
    Mar 2022
    Bedale, North Yorks
    Yes, I've ordered one, prices are all over the place but found a new oem for £20.
    I took the old one off, plug internals looked as new; since refitting it seems to have had a word with itself though and is back to normal.
    I'll fit the replacement and keep the old one as a spare.
  4. Re: Ambient temperature dash reading incorrect.
    Mar 2022
    I have the same issue apart from mine is reading - 4 degrees if not lower.
    Does anyone have the part number handy at all? Thanks.
  5. Re: Ambient temperature dash reading incorrect.
    Mar 2021
    Ripon
    7 Post(s)
    3G0820535B is the part no. I fitted.
  1. Question B6 Passat outside temperature reading on dash fluctuating
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-04-2018, 10:14 PM
  2. Question Incorrect engine temperature reading. Will this affect fuel efficiency?
    By PatchworkFish in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2011, 06:58 PM
  3. Question MPG reading incorrect?
    By briano95 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2010, 11:33 AM
  4. Temperature Gauge in Dash weird reading
    By felixoscar in forum Golf MK4 - 1999 - 2004
    Last Post: 02-02-2009, 11:18 PM
  5. Please Help Speedo showing incorrect reading
    By sumomus_01 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2008, 12:40 PM
