Thread: Audi a3 8p coding help
Results 1 to 8 of 8
  1. Audi a3 8p coding help
    Mar 2022
    Hi all,
    Was wondering if someone can help please.
    Background: My audi a3 cluster suddenly died, I tried everything from checking battery ground cables, to changing battery, new key battery, checking fuses, disconnecting battery, checking cluster connection etc. Eventually I took the cluster to be repaired, and soldering was repaired in the cluster. (car would not start, it would start for a second and die)
    I plug in the repaired cluster, and it finally powered up, allowing me to start the car successfully. Only problem was, the steering wheel had no power steering, and abs and esp light, and steering wheel light were permanently on. Red steering light and yellow abs and esp.
    After playing about on vcds, I changed adaptations on 44 steering assist, at first I cleared the codes and it made no difference. I tried to do the calibrations on the steering wheel (centre, full lock both ways) even drove for 1 hour and no difference. Then randomly I plugged it in again and cleared the codes and finally I had my power steering again!
    Unfortunately the abs and esp light is still on. I have tried to do basic settings under 03 for the G85, however it comes up as error each time I select on/off. I don't know if it is an issue with the long coding on the abs, or what the issue could be, could any gurus please give me any ideas to try on vcds? Maybe it needs a new code?
    Below is the full scan from vcds.
    Code:
    VIN: WAUZZZ8P79A008555   License Plate:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P79A008555   Mileage: 233550km-145121miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BQ    HW: 03L 906 022 BQ
       Component: R4 2,0L EDC 0000SG  3066
       Revision: --H01---    Serial number: AUX7Z0H5FNQ0C0
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 75E154D31CC13F2162-8020
       VINID: 9D196AAAA2201C9440008145146BC23099
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       Coding: 1342401209220002C81002E9901E00823800
       Shop #: WSC 06314 000 00000
       VCID: 74E769D7D7BB262955-8020
    1 Fault Found:
    00003 - Control Module
                005 - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Status: 01100101
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 233557 km
                        Time Indication: 0
                        Date: 2022.03.04
                        Time: 14:48:09
                 Freeze Frame:
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 338
                        Count: 50176
                        Count: 0
                        Count: 0
                        Count: 0
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
       Component: KlimavollautomatH08 0100
       Revision: 000376      Serial number: 8P0820043BG
       Shop #: WSC 00000 000 00000
       VCID: 72EB6FCF6DAF281947-8026
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
       Component: Bordnetz-SG     H54 2801
       Revision: 00H54000    Serial number: 00000008587242
       Coding: 1B883F81F01410807D00001F00000000000A4E076406440F002800000000
       Shop #: WSC 38100 001 00001
       VCID: 489FED273BB3F2C9C9-801C
       Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H10 0040
       Coding: 00056595
       Shop #: WSC 38100
    4 Faults Found:
    00988 - Lamp for Brake Light; Right (M10)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 233524 km
                        Time Indication: 0
                        Date: 2022.02.19
                        Time: 07:51:00
                 Freeze Frame:
                            ON
                        Voltage: 13.80 V
                            OFF
                            ON
                            OFF
                            OFF
                            ON
    01496 - Bulb for Fog-Lamps; Left (L22)
                010 - Open or Short to Plus
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 233525 km
                        Time Indication: 0
                        Date: 2022.02.19
                        Time: 07:52:00
                 Freeze Frame:
                            ON
                        Voltage: 13.85 V
                            OFF
                            ON
                            OFF
                            OFF
                            ON
    01500 - Bulb for Fog-Lamps; Right (L23)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 233525 km
                        Time Indication: 0
                        Date: 2022.02.19
                        Time: 07:52:00
                 Freeze Frame:
                            ON
                        Voltage: 13.85 V
                            OFF
                            ON
                            OFF
                            OFF
                            ON
    00987 - Lamp for Brake Light; Left (M9)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 233524 km
                        Time Indication: 0
                        Date: 2022.02.19
                        Time: 07:50:00
                 Freeze Frame:
                            ON
                        Voltage: 13.85 V
                            OFF
                            ON
                            OFF
                            OFF
                            ON
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003000000000
       Coding: 303142383038303030374A55305238503053
       ASAM Dataset: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4.rod
       VCID: 4999E823E8B90BC1D6-801C
       Crash sensor for side airbag: driver side:
       Serial number: 3572DRB40000780518FU
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3582DRB400007704DB0T
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 35128RB400003DBFC91$
       Passenger side rear thorax airbag crash sensor:
       Serial number: 35228RB400003DDC23AW
       Crash sensor for front airbag: driver side:
       Serial number: 35547RB400003CEBDF05
       Crash sensor for front airbag: front passenger side:
       Serial number: 35647RB400003CEBDFFL
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0002012
       VCID: 4189F0031889C3810E-8014
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
       Component: KOMBIINSTR. VDO H15 0820
       Revision: D0H15004    Serial number: 2245H004001749
       Coding: 0004404
       Shop #: WSC 00011 067 57207
       VCID: 397998E370599B4146-806C
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
       Component: J533__Gateway   H-- 0202
       Revision:   H--       Serial number: 00000000000000
       Coding: E9807F061002020103
       Shop #: WSC 65432 786 678678
       VCID: 356194D35C417F21A2-8060
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H15004    Serial number: AUX7Z0H5FNQ0C0
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
       Component: Tuer-SG         H03 0060
       Coding: 0000692
       VCID: 4385FA0B0295D1911C-8016
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.078 H08 1901
       Shop #: WSC 02069 000 90108
       VCID: 366393DF41477439AB-8062
    2 Faults Found:
    02546 - Steering Limit Stop
                 Freeze Frame:
                        Mileage: 233550 km
                        Temperature: 16.0°C
                        Voltage: 13.90 V
                        Voltage: 13.70 V
    00778 - Steering Angle Sensor (G85)
                000 - -
                 Freeze Frame:
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 J
       Component:    KSG          H11 0080
       Coding: 1980200002186D098F0FCC9FC637
       Shop #: WSC 06314 123 12345
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumueberw.H04 0020
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
       Component: AB2 SUBWOOFERBOXH06 0180
       Revision: 00005       Serial number: 30674802666729
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
       Coding: 0000692
       VCID: 4487F917079BD6A925-8010
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
       Component: R Concert2+     H02 0270
       Revision: 00H02000    Serial number: AUZ1Z3H8929892
       Coding: 0310211
       VCID: 3F8DF6FB6E7DB57178-806A
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
       Component: Tuer-SG         H04 0040
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
    2 Faults Found:
    00098 - Rear Left Central Locking (Safe) Motor (V163)
    00930 - Locking Module for Central Locking; Rear Left (F222)
                008 - Implausible Signal - Intermittent
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
       Coding: 0000144
       VCID: 428BFF0F1D8FD89917-8016
    End-------------------------(Elapsed Time: 02:04)--------------------------
  2. Re: Audi a3 8p coding help
    1841 Post(s)
    Have you got an old scan of the car before the cluster failed? Have you tried taking the car for a (careful) run and when stopped in a convenient place, a couple of lock to lock and holds?
  3. Re: Audi a3 8p coding help
    Mar 2022
    Hi Crasher, thanks for your response.
    Unfortunately don't have any old codes. I have driven the car for 30 miles, even tried the steering left to right full lock, however no success.
  4. Re: Audi a3 8p coding help
    1841 Post(s)
    I could have sworn that code read showed incorrect coding on the instruments when I read it? It was only 6pm so it can’t have been alcohol
  5. Re: Audi a3 8p coding help
    Mar 2022
    No mate, just the Abs error
  6. Re: Audi a3 8p coding help
    1841 Post(s)
    Finally, the plot is lost…
  7. Re: Audi a3 8p coding help
    Mar 2022
  8. Re: Audi a3 8p coding help
    Mar 2022
    Solved, did basic settings on channel 25, 26, thanks to pevag!
    All errors cleared. Finally.
  1. Audi Q7 4L ABS login coding
    By elecautocr in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-07-2019, 03:29 PM
  2. How To Audi RNS e coding
    By Jandatt in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 25-02-2019, 10:56 AM
  3. coding replacement ABS module Audi B5
    By DeeJames in forum VCDS - Help Requests
    Last Post: 19-06-2013, 04:14 PM
  4. coding ESP audi a4 2002
    By pati in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2008, 02:32 AM
  5. Audi ECU Coding...
    By NickHuge in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-11-2008, 02:25 AM
