Thread: 2009 passat cc 140hp 200k time for new oil pump?
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 2009 passat cc 140hp 200k time for new oil pump?
    1840 Post(s)
    I am glad you found that, it is a bit long winded to keep doing. For me the only test is to see the canister hold a vacuum, when running the vacuum is constantly topped up which can be misleading.
  2. Re: 2009 passat cc 140hp 200k time for new oil pump?
    Mar 2020
    ireland
    6 Post(s)
    thanks for the input i'm leaning towards the actuator as all the visible vacuum hoses (to me) are in good condition. i've heard there is some at the rear of the engine below the turbo for the egr that can split. i will try get a look at them before i order a new actuator. the fault only presents itself once in a while the coil light pops on for a few seconds and the message engine fault visit workshop if it was more frequent or limp mode id be in more of a hurry to sort it out. so many niggles i can see why the seller sold it 😂
  3. Re: 2009 passat cc 140hp 200k time for new oil pump?
    1840 Post(s)
    If you apply the vacuum to the source hose to the servo feed pipe, after a few pumps you should be able to pull and hold a vacuum indefinitely.
  1. Question 2009 Mk6 2.0tdi fuel pump??
    By Mickyroo in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2020, 10:33 AM
  2. Question 2009 A6 2.7tdi Auxillary Water Pump Fault
    By rictic68 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-09-2014, 10:35 AM
  3. 2009 audi a4 2.0tdi 143bhp oil pump shaft
    By Matt.russell in forum 2.0TDi - Engine
    Last Post: 22-11-2013, 09:49 AM
  4. 200k service report!
    By Puresilk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-04-2013, 12:35 AM
  5. 200k - A4 tdi 2.5 v6 quattro - is it worth considering to buy?
    By rabbie1969 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-08-2011, 08:01 PM
