Thread: 2018 Q7 Steering column stalk switch/module HELP
  1. 2018 Q7 Steering column stalk switch/module HELP
    Feb 2022
    Atlanta
    I have a 2018 NA Q7. Coded lane assist some time again but wife doesn't like it on all the time so I had to turn it of. Since I still want it and didn't get it from factory I decided to buy the column switch module that has the button to turn the lane assist on and off. The one that I purchased is 4M0 907 129 HF, the one that was in my car is 4M0 907 129 GD. I replaced it today, everything went great, after I turned the car I got bunch of warnings. Scanned the car with VCDS and have bunch of errors/codes. When I go to module 16-Steering Wheel I get:
    5648384 - Control Module
    C104A F0 [009] - Incorrect VIN
    I assume I'm getting this because it is a new module and needs to be adapted to the car, I couldn't figure out how to do it with VCDS or verify if that's what I need to do. My VCP PRO is on the way back to then because it failed so I don't have it to try doing it that way.
    Any help? I would love to keep the new stalk module so I can control lane assist but if I can't get it to work I'll have to take it out.
  2. Re: 2018 Q7 Steering column stalk switch/module HELP
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    I'd get in touch with Andyhud007
    He will be able to sort you out I'm sure.
  1. Column Stalk/switch part number HELP!
    By TURBOPROP in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-01-2017, 05:29 PM
  2. Question washer fluid leak on steering column - how to remove column shroud etc
    By flat4fanatic in forum Touran - Sharan - Caravelle
    Last Post: 29-03-2014, 11:28 PM
  3. Mk5 Golf steering column module help please
    By mark wade in forum VCDS - Help Requests
    Last Post: 28-11-2012, 02:21 PM
  4. steering column module
    By debjohn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2010, 09:58 PM
  5. Please Help Steering column switch trim torx screw size?
    By c4a5er in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-04-2009, 10:32 PM
