Thread: LED Low to LED High Retrofit - No High Beams
  1. LED Low to LED High Retrofit - No High Beams
    Feb 2022
    Ireland
    Hi all,
    I got a 2018 Passat GTE a few days ago, I am really excited to have a VW again. I already retrofitted a reverse camera, but I have an issue with a LED headlight upgrade.
    The car came with the basic reflector LED headlights. I purchased the below wiring adapter kit so I could retrofit the advanced LED lights.
    https://www.kufatec.com/en/volkswage...assat-b8-42225
    Importantly, I did not get the LWR module (linked below) that they recommended. The wording made me think that not getting it would mean I didn't have the corning function, which I do not care about right now. My current LWR module (module 55) is 5Q0 908 357. The CAN lines are correctly connected.
    https://www.kufatec.com/en/volkswage...ng-light-42214
    I also did not get the coding adapter they sell, as I have VCDS.
    My Problem:
    All lights work, except for the full beams (blue dash light).
    My questions:
    What coding do I have to do to tell the car that the advanced LEDs are fitted? My VCDS experience was from a Mk4 Golf, so things are more complicated!
    At first, I thought the 50 euro coding box was not needed.
    There are forum posts elsewhere which show that the headlight modules on the lamps themselves were mismatched to the car, and caused main beam failure. I was careful to buy LED headlights which were the same year as the car. I think I need to figure out what the Kufatec coding box does before I can find out if I need anything else.
    Any assistance would be great.
    Thanks!!
  2. Re: LED Low to LED High Retrofit - No High Beams
    Feb 2022
    Ireland
    This is all that VCDS has to say about fault codes.
    When I take out and reinsert the fuses for the headlights, they both point downwards as part of that initial test they and Xenons do, which I assume is done by the positioning motors.
    Address 55: Headlight Range Labels: 5Q0-907-357.CLB
    Control Module Part Number: 5Q0 907 357 HW: 6R0 907 357 A
    Component and/or Version: LWR-ECU 005 0080
    Software Coding: 03D6020009000000
    Work Shop Code: WSC 05311 000 08193
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110 (VW48)
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75E154D3D4C13F23E0-8020
    2 Faults Found:
    5276949 - Positioning Motor for Headlight Range Left
    C1085 15 [137] - Open or Short to Plus
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 186834 km
    Date: 2022.02.27
    Time: 06:49:35
    5277205 - Positioning Motor for Headlight Range Right
    C1086 15 [137] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 186834 km
    Date: 2022.02.27
    Time: 06:49:34
  3. Re: LED Low to LED High Retrofit - No High Beams
    1841 Post(s)
    Which VCDS cable do you have? Have you looked in the coding tables for clues?
  4. Re: LED Low to LED High Retrofit - No High Beams
    Feb 2022
    Ireland
    Thanks for the reply. It's a HEX interface I borrowed off a mechanic friend of mine, but they are on holidays.
    I've looked around the coding section and I can not find anything. There seems to be heaps of stuff in the adaptation section of various modules, but that's totally new to me.
    That said, I can turn my hand to this easy enough. I'm just not sure what to code. Maybe my LWR module can do basic led but not the high ones.
  5. Re: LED Low to LED High Retrofit - No High Beams
    Feb 2022
    Ireland
    Hi all.
    I picked up a new AFS-ECU (7P6 907 357 D) and now both headlights do their dance when the car is switched on.
    But I am still none the wiser on what I need to code in module 09, as I can not activate the LED headlight option in module 55 (error 31).
    For the sake of a 50 euro coding module from Kufatec, I have really wasted time on this. I just cant seem to find what coding needs to be done. I may have picked up the wrong AFS-ECU too, but now the only error on the dash I am getting is for the cornering light.
    Here are my codes: Thanks again for any help!
    Address 09: Cent. Elect. Labels: 5Q0-937-08X-V2.clb
    Control Module Part Number: 5Q0 937 086 BM HW: 5Q0 937 086 BH
    Component and/or Version: BCM PQ37BOSCH 034 0245
    Software Coding:
    Work Shop Code: WSC 00015 115 08193
    ASAM Dataset: EV_BodyContrModul1UDSBosc 018001 (VW48)
    ROD: EV_BCMBOSCH_018.rod
    VCID: 0603231FB92724BBF9-8052
    2 Faults Found:
    21772 - LED Headlamp Power Output Stage; Left
    B149C 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:22:36
    22028 - LED Headlamp Power Output Stage; Right
    B149B 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:22:36
    Address 55: Headlight Range Labels: 7P6-907-357.clb
    Control Module Part Number: 7P6 907 357 D HW: 7P6 907 357 A
    Component and/or Version: AFS-ECU H07 0090
    Software Coding: 021A01010B000400
    Work Shop Code: WSC 01357 011 00200
    ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 (VW48)
    ROD: EV_HeadlRegulVWAFSMQB.rod
    VCID: 408FF507DB83CA8B83-8014
    5 Faults Found:
    13636608 - Control Module Incorrectly Coded
    U1014 00 [137] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:10:57
    5276145 - Power Output Module for Left Headlamp
    C1081 F1 [137] - Incorrectly Coded
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:10:57
    5276401 - Power Output Module for Right Headlamp
    C1082 F1 [137] - Incorrectly Coded
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:10:57
    5275220 - Headlight
    C107E 54 [137] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:10:57
    5256725 - Rear Left Ride-Height Sensor
    C1036 15 [137] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 235
    Mileage: 187017 km
    Date: 2022.03.02
    Time: 18:10:56
  1. DAB Retrofit to MMI 2G High .. Done! (again!)
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-10-2017, 07:19 PM
  2. AMI retrofit to 2G High
    By Pork in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2017, 09:01 PM
  3. Fault code 01533 - Terminal 56 (High Beams) 36-00 - Open Circuit
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-08-2016, 08:11 PM
  4. A3 8V MMI High Retrofit from Std
    By ErVaLt in forum In Car Entertainment
    Last Post: 14-02-2015, 05:32 PM
  5. 2003 Audi A4 1.8T Avant ( High Beams turning on and off on own?!)
    By FrozenAvant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2011, 06:34 PM
