Thread: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    May 2017
    Canterbury, Kent
    57 Post(s)
    Hello to all
    I've had a series of problems on my A6, and the engine now has a very serious performance problem. Over the very recent years and forum posts - I've replaced:
    Inlet Manifold
    Throttle Body
    EGR Valve
    the Turbo itself
    Lower Intercooler Hose (in the next day or two)
    N75 solenoid
    I've had significant power problems for months and months now. I've been using a great local VAG independent specialist who I really like and trust, but even they've reached the end of what they feel that they can do, and have suggested that I try a local direct injection specialist for specialist diagnosis - hence I'm now pulling my hair out!
    SYMPTOMS:
    The car has a serious power underperformance issue. During normal (around town) driving, the car cannot accelerate beyond 3,000RPM and struggles to get to 3k at all - around town, she drives ok'ish at upto 30-40mph type speeds, when acceleration is slow.
    In the motorway environment, she is an absolute dog, and can barely outperform an HGV. She will not cruise at more than 65mph on the flat. On any sort of incline, she is completely mullered, and more so if she has been driving more than 20-30 minutes since the engine start. To give any Kent locals an idea, when trying to climb up the sharp, windy side of Detling Hill, she can only just get up it at about 35-40mph, and in 4th gear only. She will not climb this hill in either 5th or 6th. Even in 4th, she was juddering, vibrating, with the gearstick shaking. She felt like she was going to cough and splutter to a halt. On longer, but much shallower, motorway inclines - like the Eastbound stretch of the M25 towards J8 (Reigate) from J9, the car got worse and worse, struggling up the final incline at 40mph in 4th. NB. I have noticed that she does improve a little, after stopping the car, turning off the engine, locking the car, waiting for a few minutes and then restarting. I'd suggest that this small improvement only lasts about 10-20 minutes though.
    BACKGROUND:
    My local specialist has most recently replaced several items over the last few months trying to fix the problem. First it was the inlet manifold, as they noticed that the vacuum pump on the swirlflaps wasn't moving. When it came off, it was clear that the manifold was completely coked up and the swirlflaps had seized. A very clean breaker part was fitted. After this was fitted, it felt like it made an noticeable improvement, but this was soon lost, and the car's performance returned to normal (very poor) levels.
    The turbo was suspected as the candidate as the source of the problem. A recon unit was sourced and fitted, along with a new return pipe and engine service etc. They thought that the old turbo had too much play in the impeller, and they weren't happening with the audible whistling - they informed me that turbo's should be pretty much silent, and that whistling turbo's indicated that they were coming towards the end of their life. After this was fitted, again, it felt like there was an improvement in performance, but again, this very quickly returned to its present, very poor performance. The new turbo doesn't audibly whistle as the engine revs. There was a noticeable improvement in performance after the turbo was replaced, but again, this soon reverted back to normal.
    Last week, they test-fitted a new N75 solenoid. This made a very dramatic improvement in performance, and we agreed to change it and leave it on. At the same time whilst they were investigating the car, they noticed that the lower intercooler hose was extremely weak, and very flexible when you squeezed it with your hand, and was expanding noticeably with every rev of the engine. (A new intercooler hose will arrive imminently). Anyway, the new N75 was fitted, and the performance was *transformed* (positively!) - it was pretty much back to where it should be - I'd estimate it was giving 90%+ of it's expected performance, and we concluded that the weak intercooler hose, once the replacement was fitted, may well cure the last residual hesitation in some of the harder acceleration spots. I drove it away, and she was performing relatively normally. I took her to a known stretch of motorway (both approaches to Whitstable Hill on the Thanet Way - if you're local), and going Eastbound/London-bound, she was comfortable accelerating from 70 - 95mph on the slow drag uphill. Turning around and coming back Westbound, which is shorter and much steeper, the cruise control comfortably held the car at 75mph all the way up (which she wasn't able to do normally - normally, she'd drop to about 45-50mph and splutter her way up). I was confident that we'd largely cured her.
    HOWEVER - I used the car on a long drive yesterday (just four days after the N75 was fitted). I noticed immediately joining the motorway for the first time at the start of the journey, there were a few spots of hesitancy, but for the first 50-60 miles, she was driving relatively normally. She was able to keep up with higher speed traffic, and was able to cruise at 80-90mph without too much bother. However, after 60 or so miles and beyond, she simply got progressively worse and worse. In the next 60 or so miles, she rapidly declined from approx. 90% performance to really, really poor levels - indeed, by the end of the entire trip (circa 500 miles), in my opinion, she was worse than she had ever been before. I had to attempted to climb the sharp end of Detling Hill last evening on my way home, and she really struggled to get up the hill at between 35-40mph. Overall, she's absolutely terrible.
    Finally - I've noticed that when the problem is occurring, I'm having a *very* large impact on fuel consumption. Normally, she's in the high 40's for mpg. Yesterday, for the first 60 or so miles - she was at about 44mpg. However, by the end of the entire journey, she was down to 29mpg, and that's with an average speed of around 60-65mph. The fuel hit is considerable. I filled up much more than I would have expected to for the mileage covered - the fuel consumption issue is very real.
    Does anyone have any idea what the hell is going on with my engine? Does anyone know why after a new N75 is fitted, that mostly resolved the problem, is then effectively over-ruled and stopped from delivering by some other (electronic?) problem that cancelled the performance gain so quickly? My mechanics have never even heard or experienced any of these engine/performance symptoms - let alone dealt with them.
    When I think about it, when she's failing to hold speed up an incline in say 6th gear, and she starts vibrating and spluttering forcing me to change down, it does feel like a fuelling problem. I'm guessing, as a layman, that what's happening is that she's actually over fuelling (only a guess), but to me this might logically explain the coughing and spluttering and the failure to hold speed, let alone gather speed. It would also explain the excessive fuel consumption.
    She's not leaking fuel into the engine itself. I've checked. The oil level is correct, and it's not pushed up the dipstick by fuel mixing about in the block.
    Can anyone help me as to where on earth I go with this next? I know that I'm moving into some specialist territory now, and the list of specialists that really know their onions on this kind of issue is small! I'm happy to fix her, but I really need someone that knows what they're doing, and isn't simply guessing, to diagnose and then fix the problem.
    My local independents are suggesting things like injector timing, injector loom failure (both inside the crankcase and time consuming to diagnose, work on and resolve), or possibly even the ECU buggering me about. I'd be so grateful for anyone that has heard of any issues like this - helping me out with a steer or two!
    Many thanks in advance for any replies, or suggestions. I'd also really appreciate if anyone knows of a VAG specialist who they think might be able to do the work to sort this out? I've logged the performance within VCDS, but the forum won't let me upload a CSV file as far as I can see!
  2. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    1840 Post(s)
    There MUST be codes stored on the ECU, what are they?
  3. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thanks for replying Crasher - I should have added this into the OP.
    There are NO relevant codes at all!! (as far as I can see)
    This is the problem. My current mechanics are scratching their heads. I'm scratching my head. I don't know where to go next. They couldn't understand why the turbo wasn't being thrown into limp mode, when the erratic variation of actual -v- expected pressure was way more than 400 milibars difference in some instances. They were telling me that it should dump the engine into limp mode if the variation threshold of 250 milibars is breached. They were performing the "red line the car in 3rd" to test the turbo performance when they were logging their own VCDS readings. Theirs's showed the same variation in pressure readings that mine did.
    There are "some" VCDS codes, and I'll paste them in at the bottom of this post - but it's an engine mount sensor, some sort of cluster fault, a glowplug error, an occasionally temperamental bulb, and low battery warnings and a occasionally temperamental oil sensor (which is less than a year old). I have had electronic gremlins in the car previously, which I eventually tracked down as being a faulty control head (replaced) - at the time, the problems being created by the control head were mainly a mahoosive battery drain that killed a battery and refused to let the car shut-down after locking, and also threw up the oil sensor and HVAC sensor codes - here's what it finds and reports:
    Code:
    Wednesday,02,February,2022,17:03:44:30461
    VCDS Version: 21.9.0.2 (x64)
    Data version: 20210903 DS330.0
    Ross-Tech: Home
    VIN: WAUZZZ4F58N003147   License Plate: BT07JDO-02022022
    Mileage: 191500km-118992mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
              62 72
    VIN: WAUZZZ4F58N003147   Mileage: 191500km-118992miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-016-BLB.clb
       Part No SW: 03G 906 016 MH    HW: 03G 906 016 MH
       Component: R4 2,0L EDC G000SG  0948
       Revision: --H05---    Serial number:
       Coding: 0000072
       Shop #: WSC 02325 758 00200
       VCID: 75E15DB81CB7CB2162-8020
       VINID: 9D196AAAA1161487800030441C50EAB596
    3 Faults Found:
    005512 - Engine Mount Solenoid Valves (N144/N145)
                   P1588 - 000 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 3
                        Fault Frequency: 10
                        Reset counter: 255
                        Mileage: 191097 km
                        Time Indication: 0
                        Date: 2022.01.29
                        Time: 11:42:25
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 11.48 V
                        Bin. Bits: 00101000
                        Torque: 0.0 Nm
                        Torque: 351.4 Nm
    005716 - Please check DTC Memory of Instrument Cluster
                   P1654 - 000 -
                 Freeze Frame:
                        Fault Status: 01110000
                        Fault Priority: 6
                        Fault Frequency: 10
                        Reset counter: 255
                        Mileage: 191097 km
                        Time Indication: 0
                        Date: 2022.01.29
                        Time: 11:42:30
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 11.55 V
                        Temperature: 33.3°C
                        Temperature: 65.7°C
                        Temperature: 12.6°C
    001668 - Glow Plug Control Module (J179)
                   P0684 - 000 - Implausible Signal
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 191108 km
                        Time Indication: 0
                        Date: 2022.01.29
                        Time: 17:31:47
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 12.08 V
                        Bin. Bits: 00101100
                        Temperature: 19.8°C
                        Bin. Bits: 00110000
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020855
       VCID: 65C10DF8AC173BA1D2-8030
    No fault code found.
    Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100784323
       Coding: 0000145
       Shop #: WSC 23883 002 1048576
       VCID: 63C513E0A22345913C-8036
       Subsystem 1 - Part No: 4F0 910 132 F
       Component: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0054
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
       Part No SW: 4F0 910 732 H    HW: 4E0 035 729
       Component: Interfacebox    H43 5140
       Revision: 00000000    Serial number: 350KU077834154
       Coding: 0001010
       Shop #: WSC 00751 202 55154
       VCID: 285F44CC9B85E6C929-807C
       Subsystem 1 - Part No: 4F0 910 609 E
       Component: Bedienteil MMIC6H01 0060
       Subsystem 2 - Serial number: 00000000764240
       Subsystem 3 - Serial number: 0121.05.070000000100010761ÿ
       Subsystem 4 - Serial number: 010761ÿ
    1 Fault Found:
    01327 - Control Module for Parking Aid (J446)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 19
                        Mileage: 184138 km
                        Time Indication: 0
                        Date: 2021.10.25
                        Time: 17:50:19
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000000396020
       Coding: 0001300
       VCID: 1C37681CDFDD3A69BD-8048
    1 Fault Found:
    01232 - A/C Compressor Regulator Valve (N280)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 3
                        Fault Frequency: 9
                        Reset counter: 154
                        Mileage: 189784 km
                        Time Indication: 0
                        Date: 2021.12.29
                        Time: 14:17:30
                 Freeze Frame:
                        Load: 90.0 %
                        Current: 0.040 A
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H17 0240
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0001101
       Shop #: WSC 02335 758 00200
       VCID: 3169A9A8A85FA701FE-8064
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00146221
       Shop #: WSC 02335
    1 Fault Found:
    01500 - Bulb for Fog-Lamps; Right (L23)
                 Freeze Frame:
                        Fault Status: 00111010
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 136
                        Mileage: 190692 km
                        Time Indication: 0
                        Date: 2022.01.09
                        Time: 20:22:00
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0390
       Revision: 00046004    Serial number: AUZ5ZBG3405407
       Shop #: WSC 00000 000 00000
       VCID: 1A3B6E04D5E94459AF-804E
    Address 15: Airbags        Labels: 4F0-910-655-8R.clb
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0RXPFF
       Coding: 0013381
       VCID: 295941C8808FDFC136-807C
       Subsystem 1 - Serial number: 6332CSME195C4D66H
       Subsystem 2 - Serial number: 6342CSME1A24724D5
       Subsystem 3 - Serial number: 6352QSME302C5179G
       Subsystem 4 - Serial number: 6362QSME30332401.
       Subsystem 5 - Serial number: 63734SME2C771C4DG
       Subsystem 6 - Serial number: 63834SME28434843
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0410
       Revision: 00H02000    Serial number: 90026071410371
       Coding: 0102042
       Shop #: WSC 02323 758 00200
       VCID: 275D47F0969BE9B120-8072
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H07 0080
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4F0 920 982 T
       Component: KOMBIINSTR. M73 H21 0220
       Revision: 00500000    Serial number: 6IL57EJ57
       Coding: 3332458
       Shop #: WSC 12345 123 12345
       VCID: 234553E0E2A305917C-8076
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 114
                        Mileage: 191097 km
                        Time Indication: 0
                        Date: 2022.01.29
                        Time: 11:45:30
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 13008075198085
       Coding: 6CEE53C41B2104
       Shop #: WSC 02334 758 00200
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 110
                        Mileage: 191126 km
                        Time Indication: 0
                        Date: 2022.01.29
                        Time: 18:04:54
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H49 1060
       Revision: 00000000    Serial number: 364EX077683552
       Shop #: WSC 00581 210 58432
       VCID: 3B758B807A135D5154-806E
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
       Component: TSG FA          H12 0210
       Revision: 00-00000
       Coding: 0003610
       Shop #: WSC 02327 758 00200
       VCID: 2C57B8DC8F7DCAE9CD-8078
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H25 0200
       Revision: 02000025    Serial number: 01045460260000
       Coding: 0262907
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
       Component: Amp.-ASK-RD   H07 0270
       Revision: 09S00000
       Coding: 030001
       Shop #: WSC 02399 823 56573
       VCID: 285F44CC5B85E6C929-807C
    1 Fault Found:
    00419 - Left Front DSP Midrange Speaker (R103)
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00111011
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 151
                        Mileage: 186617 km
                        Time Indication: 0
                        Date: 2021.11.27
                        Time: 18:54:56
                 Freeze Frame:
                        Voltage: 12.00 V
                        Temperature: 1.0°C
                        Bin. Bits: 00000011
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000338240
       Coding: 0001114
       VCID: 5EB322148941687913-800A
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
       Component: TSG BF          H12 0210
       Revision: 00-00000
       Coding: 0003610
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000111
       Shop #: WSC 02324 758 00200
       VCID: 204F5CECF3B51E8961-8074
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 394I+077807843
       Coding: 0000001
       VCID: 2E53B2D4B961B8F9E3-807A
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000079138
       Subsystem 1 - Part No: 4F0 915 105 D
       Component: von VA0  2705210154
       Coding: 344630393135313035442056413032373035323130313534
       Shop #: WSC 12345 512 00290
    5 Faults Found:
    02272 - Quiescent Current Stage 1
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 7
                        Fault Frequency: 5
                        Reset counter: 255
                        Mileage: 190789 km
                        Time Indication: 0
                        Date: 2022.01.15
                        Time: 16:52:11
    02273 - Quiescent Current Stage 2
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 190789 km
                        Time Indication: 0
                        Date: 2022.01.15
                        Time: 16:53:26
    02276 - Quiescent Current Stage 5
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 190789 km
                        Time Indication: 0
                        Date: 2022.01.15
                        Time: 16:53:35
    02274 - Quiescent Current Stage 3
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 190789 km
                        Time Indication: 0
                        Date: 2022.01.15
                        Time: 16:53:45
    02277 - Quiescent Current Stage 6
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 190789 km
                        Time Indication: 0
                        Date: 2022.01.15
                        Time: 16:53:55
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0050
       Coding: 0003074
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0050
       Coding: 0003074
  4. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    May 2012
    Everywhere
    308 Post(s)
    Still could be worse .
  5. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by Gazwould View Post
    I should probably get that as a joke... but I don't!
  6. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    May 2012
    Everywhere
    308 Post(s)
    It's not a joke it's a 13 years aware planned obsolescence time bomb device .
  7. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Blocked or collapsing cat maybe?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  8. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    In your post you mention " and a occasionally temperamental oil sensor " although it doesn't show in your VCDS log.
    If it were a low oil pressure warning I could see that putting the engine into limp mode, although I don't know that for a fact.
    EDIT Sorry, just noticed it in Instruments -
    So probably not relevant.
  9. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    1840 Post(s)
    I would be doing a requested and actual boost graph.
  10. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by dean warren View Post
    Thanks Dean.
    I don't want to hear that it might be the Cat! :-(
    Is there a way to test for this being the possible cause?
  1. Question Engine issues: Vw 1.4tsi caxa engine.
    By otieka in forum Golf MK5 - 2004 - 2009
    Last Post: 05-02-2017, 03:43 PM
  2. A4 Engine Issues
    By Scotteire in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-05-2015, 11:08 AM
  3. A3 BFQ Engine power issues at low RPM
    By AirBoy in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-02-2015, 10:26 PM
  4. Another problem - suspension issues & engine workshop
    By dirtyderv in forum Bora - 1998 - 2005
    Last Post: 16-02-2008, 01:53 AM
  5. A4 2.0 TDI Engine issues
    By HighKite in forum Audi A4 - Archive Topics
    Last Post: 27-08-2007, 08:39 AM
