Thread: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #21
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by Gazwould View Post
    Excellent news .
    Now for the next fix .
    Attachment 38462
    Tell me about it... I'm looking forward to a nice long run of reliability for some months now!
  2. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #22
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by dean warren View Post
    Oh glad you sorted it, looking at the depths you had already gone to I assumed you had already done the filter… lol never mind
    Thanks Dean
    In all these months, and after a number of garages and mechanics, not a single one has asked me whether it had been replaced, or suggested it should be... (they were suggesting potential causes like the injectors, injector loom, exhaust, ECU corruption and other far harder to track down potential causes). If they had, I would have changed it out months ago! I didn't even know it was a possible cause of power problems like this until I started looking at it myself last week.
    I do lose faith in these mechanics. I don't think they know half as much as they suggest or think they do....
  3. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #23
    May 2012
    Everywhere
    308 Post(s)
    Ignore the chain driven part as yours is geared but pay attention to the balancer shaft keyway and 77mm oil pump drive part.
  4. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #24
    Mar 2010
    Derry ireland
    60 Post(s)
    This cure to me certainly does not add up in my book
  5. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #25
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by mickeybo View Post
    What exactly are you saying Mickey - because it sounds an awful lot like you just called me a liar in writing...
  6. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #26
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thanks Gaz
    What's this for?
  7. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #27
    May 2012
    Everywhere
    308 Post(s)
    The fix is a properly engineed balancer shaft keyway and longer 100mm hex key for superior contact surface area and fit .
    Kit 9 .
    All Products - KMB Parts Direct specialist, Oil pump replacement parts, Audi 2.0tdi, VW 2.0tdi, engines, support, help, advice, Sheffield, UK, England.
  8. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #28
    May 2017
    Canterbury, Kent
    57 Post(s)
    Kit 9 .
    Thank you.
  9. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #29
    1840 Post(s)
    Quote Originally Posted by rjsdavis View Post
    You are being a bit sensitive there I understood his meaning and with no sense of calling you a liar. I think he was saying what I was thinking, he/I can't make sense of the symptoms and cure as I like to understand why things happen although to a certain extent I have given up asking why and just accept the fix.
  10. Re: A6 / C6 - 2.0 TDI (BRE) Serious Engine Problem - Serious Underperformance Issues
    #30
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thanks Crasher
    I don't especially understand the cure -v- symptoms either, but what I've reported here on this thead are facts. I don't understand why, when the solenoid was fitted, she was immediately (mostly) ok, then prgressively degraded back to really awful again through the 60 odd miles that were driven from being fitted. This does not make sense to me at all - I would expect something new, when fitted, to either work immediately or not work. Not to work, and then rapidly get overruled by another system or issue like this.
    However, I don't expect the voracity of what I've written to be called into question in any way. I come onto this forum hoping to find some expertise to help me work out what might be going wrong in a certain scenario. I bothered to update with the cure and resolution (unlike most people), as I hope that it will go on to help others who might experience the same or similar symptoms in the future. This is why I contribute to and use forums.
    The more I've looked since the fix was found, "fuel filter" comes up pretty much as the No. 1 suspected culprit in all diesel engine power problems everywhere. I still can't understand why no mechanic suggested we look at it, or change it - at all! I still can't believe I didn't complete this most simple of google searches myself 6 months ago... My friend, who was looking at it at the weekend and fitted it amongst a couple of other things, is a main ******* master mechanic, and even he hadn't thought of it - and described my suggestion as a "good shout".... (after having already replaced the turbo for me). It's just so unbelivably frustrating sometimes.
    When someone writes: "This cure to me certainly does not add up in my book" - as far as I can see, it can only be read to say: "Your reported cure is BS". There are no grounds to challenge what I've written, as I've stated facts at every step, on every thread. To do otherwise would make me somewhat psychopathic, to have wasted everyone's time, including my own.
  1. Question Engine issues: Vw 1.4tsi caxa engine.
    By otieka in forum Golf MK5 - 2004 - 2009
    Last Post: 05-02-2017, 03:43 PM
  2. A4 Engine Issues
    By Scotteire in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-05-2015, 11:08 AM
  3. A3 BFQ Engine power issues at low RPM
    By AirBoy in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-02-2015, 10:26 PM
  4. Another problem - suspension issues & engine workshop
    By dirtyderv in forum Bora - 1998 - 2005
    Last Post: 16-02-2008, 01:53 AM
  5. A4 2.0 TDI Engine issues
    By HighKite in forum Audi A4 - Archive Topics
    Last Post: 27-08-2007, 08:39 AM
