Thread: Fuel pressure warning?
  1. Fuel pressure warning?
    Feb 2014
    Oxford
    7 Post(s)
    My Q5 (2010 reg 3.0 Diesel 8RB 176KW) has started showing the coil warning light and limping, but only at first startup of the day and only it seems after a colder night, it didn't do it this morning. When it does do it though I drive a little way, then stop, turn off and turn on again and it clears for the rest of the day. My diag box tells me I have P008800 (Fuel Rail/System Pressure - Too High) and also P106500 ("Fuel Pressure Regulation - Control Difference"). Now is this likely to be just a wonky pressure regulator or could it be something worse?
  2. Re: Fuel pressure warning?
    1840 Post(s)
    Remind me tomorrow and post the VIN, I remember seeing a TSB in ELSA about this; any strange noises at idle?
  3. Re: Fuel pressure warning?
    Feb 2014
    Oxford
    7 Post(s)
    Hmm no obvious funny noises as far as I can tell, or at least no new ones! VIN is WAUZZZ8R1AA096640.
  4. Re: Fuel pressure warning?
    1840 Post(s)
    You need to remove the N290 and check the screen for swarf. Do not damage the seals, you cannot buy them and clean the area around the valve before removing it.
  5. Re: Fuel pressure warning?
    Feb 2014
    Oxford
    7 Post(s)
    Swarf? Where on earth has that come from?? What's grinding itself up in there???
  6. Re: Fuel pressure warning?
    1840 Post(s)
    The high pressure fuel pump eats itself, usually after a filter change or a misfuelling event.
  7. Re: Fuel pressure warning?
    Feb 2014
    Oxford
    7 Post(s)
    Oh lordy, this sounds expensive .....
    Ok I'm not aware of any fuel mix-ups, and the filter may well need doing but it's not been changed since we've owned the car. However, if I do find iron filings then I'm guessing it's probably time to be looking at a new fuel pump? If so, are we looking at OEM only or are there any pattern parts worth considering?
  1. Replies: 6
    Last Post: 02-06-2021, 09:03 PM
  2. Limp mode, low fuel pressure, air in fuel lines
    By Mowbz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-03-2017, 06:24 PM
  3. Low oil pressure warning!!!
    By Martya4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-04-2015, 07:42 PM
  4. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  5. Question T5 Warning Buzzer/Gong & Low Fuel Warning question
    By graeme86 in forum The Commercial Range
    Last Post: 01-02-2014, 08:50 PM
