Thread: The case of the mysterious ignition problem.
  1. The case of the mysterious ignition problem.
    Dec 2017
    Glasgow,Scotland
    Thought I'd throw this one out to the hive to see if any boffins can shed some light on this.
    I've had 2 drained batteries since this started occurring. Both times when my wife forgot to wiggle the key upon removal. Easily done. I'm going to check the battery condition and for any parasitic drain just in case anyway.
    The problem seems to be that when I remove the key from the ignition, there is no little click, which then turns the accessory mode off. However, if I wriggle the tip of the key in the cylinder, it causes it to click and turns off accessory mode. If I don't the radio and all accessories stay on, and then we have a flat battery if this happens a few times.
    I changed the ignition switch just in case it was that simple, but as I suspected that did nothing. Sprayed wd40 etc into the barrel to see if that would help. Still no change. I can't imagine changing the actual cylinders will help this either? Also, I've noticed that if I don't get the little click, the steering lock won't engage. Obviously, after getting the little click. Everything works fine.
    Can anyone tell me what may be causing this?
  2. Re: The case of the mysterious ignition problem.
    1840 Post(s)
    Sounds like a Sharan 1?
  3. Re: The case of the mysterious ignition problem.
    Dec 2017
    Glasgow,Scotland
    No, Vw T5.1 Shuttle. Wrong forum?
  1. Please Help Mysterious CAYC problem
    By Bodevo in forum Leon
    Last Post: 06-09-2023, 11:50 AM
  2. Mysterious Brake Problem!
    By FWB in forum Golf MK6 - 2009 - 2013
    Last Post: 20-12-2016, 10:28 AM
  3. crank case breather problem
    By greggie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-08-2012, 10:07 PM
  4. Serious and mysterious engine problem.
    By The Jeep in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2011, 07:06 PM
  5. Ignition Problem
    By theprodigy in forum Golf MK3 - 1993 - 1999
    Last Post: 20-04-2009, 07:50 PM
