Thread: Audi a3 jerky pull away
  1. Audi a3 jerky pull away
    Feb 2022
    London
    Hi everyone. I have a audi a3 2010 automatic (8pa). My car jerks when I change gear from neutral to drive or reverse to neutral even i don't release the brake pedal. I think gear does not engage first time. It engages at 3rd attempt. After pulling off there is no problem. It is smoothly changing between gears.
    Do you think the problem is Mechatronic?
  2. Re: Audi a3 jerky pull away
    1840 Post(s)
    There are two versions neither of which are traditional automatic boxes, the DQ200 seven speed dry clutch DSG and the DG250 six speed wet clutch DSG, both of which are automated manuals and both very different from each other; and then there is the all wheel drive version.
  3. Re: Audi a3 jerky pull away
    Feb 2022
    London
    Thanks for your reply.
    It is 6 speed. I didn't noticed this stuttering behaviour before. My mechanic said Mechatronic unit that pushes gear has worn and in a few months i will get for other gear changes also. I am not satisfied with his assumption though
  4. Re: Audi a3 jerky pull away
    1840 Post(s)
    No, to me that is the clutch pack, DQ250 mechatronic failure is frankly very rare, unlike with the D200 which is a pile of poo.
  1. Audi a6 s tronic jerky take off
    By Yuri in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-10-2020, 06:10 PM
  2. The infamous audi a4 pull back problem, or not.
    By sammydfp36 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2016, 09:45 AM
  3. Audi A4 B7 2.0 Tdi BLB Jerky / Total Loss of Power
    By chrisd1983 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-12-2014, 12:47 PM
  4. Jerky and Hissing Audi A6 2.0 tdi
    By Smithy23 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-06-2011, 08:44 AM
  5. Audi 1.6 engine jerky on acceleration
    By thomaslab in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 08:10 PM
dsg
