Thread: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
  1. 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    Dec 2011
    Swindon
    9 Post(s)
    hi all, i got these two codes from a VCDS scan. When driving the car it show glow plug light flashing and think it went into limp mode. i pulled over turned off the engine, restarted it and there were no issues.
    Are these two components related to each other? I replaced the intake manifold in summer 2019, so if that is faulty can it make the booster pressure regulator go in to fault mode?
    car is a 2007 2.0 litre tdi A6
    the last time i took off the egr valve and other components around it to clean must have been about summer 2018.
    I have read somewhere that the turbo might need to come off and have a clean.
    P3103 - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 15
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.54 V
    Bin. Bits: 00001011
    Torque: 0.0 Nm
    Torque: 300.1 Nm
    P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 252658 km
    Time Indication: 0
    Date: 2022.02.05
    Time: 11:19:32
    Freeze Frame:
    RPM: 2394 /min
    Speed: 66.0 km/h
    Load: 57.3 %
    Voltage: 13.76 V
    Bin. Bits: 00101000
    Absolute Pres.: 2325.6 mbar
    Absolute Pres.: 2590.8 mbar
  2. Re: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    134 Post(s)
    2007 Post(s)
    What is the VIN?
  3. Re: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    Dec 2011
    Swindon
    9 Post(s)
    Hi Crasher, i PM'd you my VIN
  4. Re: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    134 Post(s)
    2007 Post(s)
    A BRE engine, I need to check the diagram at work but overboost is usually a carbon clogged turbo.
  5. Re: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    Dec 2011
    Swindon
    9 Post(s)
    thanks Crasher, if it is a carbon clogged turbo would a blast up the motorway in 4th gear doing 70mph sort it? Some kind of engine fluid poured into the fuel tank? or take off the turbo and clean it manualy? I have seen lots of vidoes on the internet of people spraying oven cleaner in the turbo and leaving it for a few hours.
  6. Re: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    Mar 2010
    Derry ireland
    67 Post(s)
    The inlet manifold valve (control) motor & the turbo pressure control share the same 12v feed & a inlet manifold tuning valve. The inlet manifold can be checked out by it has 4 terminals marked 1-2-3-4 a 12v & term 2 & earth term 1 if your valve does not work replace it
  7. Re: 2 fault code. 012547 - Motor for Intake Manifold Flap (V157) & 000564 - Boost Pressure Regulation
    134 Post(s)
    2007 Post(s)
    If is was the feed from SA2 you would expect N75, 345, N316, N275n N79, N144 and J179 errors unless the red/blue welded connection in the harness near the ECU has a selective fault so I would say clogged up turbo (no, an Italian tune or snake oil treatments do not work long term if at all) and a failed V157, both very common faults and the operation of both can be checked in output tests and basic settings.
  1. Please Help V157 motor for intake manifold flap
    By T!M in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-01-2020, 05:38 PM
  2. Motor for Intake Manifold Flap (V157): Malfunction
    By b1nuzz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-11-2019, 02:46 PM
  3. Motor for Intake Manifold Flap V157 Malfunction P3103
    By Bubbauk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-02-2017, 11:11 PM
  4. Please Help V157 P3101, P3102 Motor for intake manifold flap MIL Fault investigation
    By rabb5it in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2014, 10:53 AM
  5. P3103 V157 - Motor Intake Manifold Flap
    By James Clews in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-02-2014, 09:33 PM
