Thread: fault code?
  1. fault code?
    Jun 2012
    Surrey
    the A3 is playing up again! glow plug emission warning light and limp mode intermittent.
    Only fault code is
    01027 rear warm air fan (v47)
    is anybody able to give me heads up as to what this code is and may it be the issue?
  2. Re: fault code?
    1840 Post(s)
    I get that as
    16787(P0403)001027 - Exhaust Gas Recirculation (EGR) Valve (N18): Malfunction
    Which controller is that in? Which code reader are you using? As far as I can see no 2009 A3 has a V47...
  3. Re: fault code?
    Jun 2012
    Surrey
    Hi Crasher....thanks as usual! I have used three scanners.
    An elderly but ok Sealey which includes Audi gave that code and cleared it too.
    An up to date foxwell scanned no code but maybe I dont know how to use it fully yet haha.
    An old cheapo VW AUDI one also picked the same code up.
    Wife took car out today and it threw on the glow plug light, went into limp. She stopped the car and restarted and all was fine.
    That is what it does...stop and restart and all good for a bit.
    I have not re scanned yet but will tomorrow.
    Its a 2.0 tdi 170bhp CBBB engine.
    Could it be EGR? but what that code means is a mystery to me.
  4. Re: fault code?
    Jun 2012
    Surrey
    scanned again, got sense now....P0 403 EGR. Looks like its the EGR then....can I test it electrically on to check the solenoid.
  5. Re: fault code?
    1840 Post(s)
    It will be full of crud, part number 03L 131 510 K. For what they cost aftermarket (Pierburg are perfect, as OE) from our point of view it is more cost effective to replace than and the V157 flap in front of it will be clogged solid too, disgusting job.
  6. Re: fault code?
    Jun 2012
    Surrey
    thanks Crasher......it was fully stripped and cleaned about 2 years ago....30K miles, so I suspect stuffed anyway. I will get another.
    Russ
  1. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  2. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  3. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
