Thread: Car starting trouble when cold with New battery
Results 1 to 9 of 9
  1. Car starting trouble when cold with New battery
    Sep 2012
    Romford, UK
    Hi all, I had a few issues with my battery and car starting few months back. I got a brand new battery in July and the car worked find and I had no starting problems.
    At the same time, I did a parasitic draw test using help on this forum and confirmed that there is not a lot of draw causing battery to drain when off. Battery is a Varta I1 110AH 920CCA.
    Now 6 months later, my car is having starting problems again. When I turn the ignition on, I often get the Parking brake, ESP and Glow Plug lights on and they stay on. If this happens my car doesn't start. I still have my old battery I replaced 6 months ago. If I jump start using my old battery the car starts fine. I have charged my car battery and left it on trickle charge for the last 10 days without using it. The battery shows fully charged, but I am unable to start the car. I made sure the charger is working using a volt meter. What could be the problem?
    I lost my bluetooth OBD scanner, so unable to read any codes now. Last time I checked after replacing the battery and the control flap in July, there were no codes.
  2. Re: Car starting trouble when cold with New battery
    Jul 2008
    Lisburn
    16 Post(s)
    its a faulty relay - i cant mind which but it is responsible for powering up said control modules - the extra juice is just helping it function i would say.
    I had those errors and lived with them too long as i read about people changing out control modules and complete can bus systems...
    If you do a search for my posts a few years back you should get the part number - its located below the ECU from memory, and is cheaper from Audi then off ebay!.
    good luck.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Car starting trouble when cold with New battery
    Sep 2012
    Romford, UK
    @swwalker thanks for the info. I believe this is the thread you are referring to. Problems starting...still. - Page 2
    I found the relay is about £14 including delivery from *******. https://www.*******.co.uk/bosch/1154825
    Can you please let me know if this is the right part? It looks like a number of different Amperage relays are being sold with the same part number.
    I will look into how to fit this. Or may be I have to get a local garage to do it for me if it's too hard. Also while I am at it, are there any other relays, fuses I should consider replacing in this fuse box?
  4. Re: Car starting trouble when cold with New battery
    Jul 2008
    Lisburn
    16 Post(s)
    Thats the one j317. I dug out my invoice - part number on it is 4H0 951 253 seems to be a standard relay.
    7 zap will probably detail the correct amperage
    Its easy to swap out - tricky to get to - wipers off and trim from below window off.
    Stewart
  5. Re: Car starting trouble when cold with New battery
    Sep 2012
    Romford, UK
    @swwalker Thanks for your help identifying the problem. I am struggling to find the part. What is this actually called if I phone Audi. I checked on Auto Doc website, but with this part number, I am getting 4 pin and 5 pin relays ranging from 20A to 70A.
    PS. Didn't know what 7 Zap was from your previous comment. Figured out it is a website . Now checking.
  6. Re: Car starting trouble when cold with New battery
    Jul 2008
    Lisburn
    16 Post(s)
    I called it can bus relay - my original post goes back to this post
    3.0tdi Allroad brake fault alarm on switch on. "J317 (614) - part number 8E0 951 253"
    J317 is the location reference on the schematic audi should know from this - 614 is the identifier / what type it is
    Stewart
  7. Re: Car starting trouble when cold with New battery
    Sep 2012
    Romford, UK
    Thank you very much. Ordering this now. Glow Plug Control Unit fits OPEL OMEGA B 2.5D 94 to 01 ECU Bosch 1238612 Quality 3165143407677 | eBay
    If I understand from the previous thread, I will need to remove the driver side windscreen wiper and the plastic trim under the bonnet which will give me access to the ECU box on the driver side. Hopefully I can give it a try this weekend.
  8. Re: Car starting trouble when cold with New battery
    Jul 2008
    Lisburn
    16 Post(s)
    Both wipers and not just the plastic trim under the bonnet also the trim attached to the screen - clean the she wee out while you are there as that seems to be the start of all this trouble somehow - and its on the left hand side of the car. make sure your drains are clear also while in there. if you look here :- Elsa online. ElsaWin. ElsaWeb. Audi on how to remove wiper mechanism /gearbox that will show you how to remove the trim required. you don't need to remove the mechanism but that procedure will give you the instructions you need to get to the ECU box. it wil probably even tell you how to remove the ECU, the ecu does not need unplugged to access the relay from memory.
    Stewart
  9. Re: Car starting trouble when cold with New battery
    Sep 2012
    Romford, UK
    I got my bluetooth OBD2 scanner today and was able to scan the diagnostic codes. Are these relevant to the cold start problem? I cleared them and they didn't come back after idling for about 5 mins.
    ============1==============
    0384
    Raw code: 0180
    ECU: 19. CAN Gateway
    Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
    Audi A1 2019; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; Q7 2016: B10CE00: Blower reduction due to energy management
    Audi: C101D01: Right rear ABS wheel speed sensor
    Electrical error
    Audi: B2F0600: Development code 6
    Audi: B187400: Aux. heat/ventilation
    Heater runtime exceeded
    Audi: Optical data bus
    ============2==============
    1314
    Raw code: 0522
    Status: Test conditions are met, Validated and stored in non volatile memory
    Audi: Engine control unit
    ============3==============
    2083
    Raw code: 0823
    ECU: 03. ABS control unit
    Audi: C119A12: Stationary cornering light
    Short circuit to B
    Audi: Message to request a slowdown; Message for delay request
    ============4==============
    1314
    Raw code: 0522
    ============5==============
    18055
    Raw code: 4687
    Audi: P1647 Check coding / modifications of transmission control units; Check coding / variants of the control units in the drive train
    ============6==============
    1314
    Raw code: 0522
    ECU: 08. Heater and climate
    Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
    ============7==============
    1314
    Raw code: 0522
    ECU: 17. Dashboard
    ============8==============
    0912
    Raw code: 0390
    ECU: 42. Driver door electronic equipment
    Audi: Front Left Power Window Switch-E40; Front left window regulator switch-E40; Camshaft position sensor => encoder-G301 malfunction
    ============9==============
    1314
    Raw code: 0522
    ECU: 46. Central comfort systems module (VW TP2.0)
    ============10==============
    1314
    Raw code: 0522
    ECU: 4F. Body control unit #2 (VW TP2.0)
    ============11==============
    1316
    Raw code: 0524
    ECU: 53. Parking brake
    Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory
    Audi: Brake control unit
    ============12==============
    1314
    Raw code: 0522
    ============13==============
    1299
    Raw code: 0513
    ECU: 61. Battery Regulation using CAN (VW TP2.0)
    Audi: Data Bus Diagnostic Interface-J533; Diagnostic interface for data bus J533; Wrong immobilizer code
  1. Please Help Audi 1.9 TDI 2005 - Trouble starting in cold weather?
    By K7L3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-10-2016, 04:58 PM
  2. Trouble starting from cold and judder at idle on 1.9 PD engine
    By iaindhill in forum Golf MK5 - 2004 - 2009
    Last Post: 27-10-2014, 05:52 PM
  3. Trouble cold starting after new injector
    By mm707 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-11-2010, 03:01 PM
  4. Please Help Cold start trouble.
    By soulstyler in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2010, 01:01 PM
  5. A3 Cold Starting Trouble
    By GHanson in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 27-03-2008, 10:33 AM
