Thread: BRE Crank Sensor location
Results 1 to 10 of 13
  1. BRE Crank Sensor location
    Apr 2018
    Dunkeswell
    Hi all, recently out and about and the car just cut out, wouldn’t restart. It cranks but won’t fire, has a PO726 fault code suggesting crank sensor issue.
    Mat sound like a daft question but which plug is the crank sensor on these? Anyone have a decent picture of where it sits?
    Thanks In advance
  2. Re: BRE Crank Sensor location
    Mar 2010
    Derry ireland
    60 Post(s)
    The fault code on your bre engine code po726 covers a multitude location at the moment does not matter. This can be checked out via ecu pin outs b42 & b58 & b57. The pin no b57 is the switched ecu earth wire colour black I would be inclined to check out this earthing first & foremost
  3. Re: BRE Crank Sensor location
    Apr 2018
    Dunkeswell
    Ah so check theres a continuity between b57 & engine/body earth?
    Any pin outs for the ecu available?
    I’d wondered If there’d be more to this lol. Can’t say I’ve come across any disconnected or broken wiring while I’ve been looking around the engine yet though
  4. Re: BRE Crank Sensor location
    1840 Post(s)
    The G28, it is on the crank oil seal holder down inside the bellhousing through an access hole. You need a very good quality shar, new, ball ended 4mm long hex key, I keep a Snap Off one specially for this job and take great care doing it because if you round out the head of the bolt it is gearbox out flywheel off. It is worth noting that on these, condensation in the EGR flap motor can cause a false error for the G28.
  5. Re: BRE Crank Sensor location
    Apr 2018
    Dunkeswell
    Is it accessible without removing any other parts? I presume so but fiddly?
    What causes the condensation in the EGR? I’m the run up to the breakdown the car hadn’t been used a lot would this have contributed?
    Cheers 👍
  6. Re: BRE Crank Sensor location
    1840 Post(s)
    Message me the reg or post the VIN so I can check on Elsa if the EGR idea applies to yours, the moisture gets in there from the exhaust fumes which contain water.
  7. Re: BRE Crank Sensor location
    Apr 2018
    Dunkeswell
    Don’t seem to be able to message you but the Reg is ML07LUT
  8. Re: BRE Crank Sensor location
    1840 Post(s)
    Remind me Monday
  9. Re: BRE Crank Sensor location
    Apr 2018
    Dunkeswell
    Remind me Monday
    Hi mate, any news?
    Garage seem to think the crankshaft sensor is the fault but are saying it’s a definite gearbox off job to sort. I presume it's doable without though? Is there an access hole specifically to get to the bolt?
  10. Re: BRE Crank Sensor location
    Mar 2010
    Derry ireland
    60 Post(s)
    removing gearbox to my way of thinking to coin a phrase putting the cart before the horse. I stand by what i first posted up
  1. crank/speed sensor or cam sensor
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-04-2010, 08:31 PM
  2. Oil From Crank Sensor
    By willowraf in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2009, 10:56 PM
  3. Please Help 1.4 16v crank sensor
    By stu16v in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2009, 07:25 PM
  4. Crank Sensor?
    By my1stGTi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-04-2007, 08:58 PM
