Thread: Activating wireless Apple CarPlay 2029 A6 Avant
Results 1 to 9 of 9
  1. Activating wireless Apple CarPlay 2029 A6 Avant
    Feb 2017
    Lincoln, UK
    I was pretty disappointed to find that my 2019 A6 SLine Avant didn't come with wireless Apple CarPlay from the factory, and even more so once the salesman told me it was only available on later models.
    Well, this morning, I've sorted it out.
    If you've got a HEX-V2 VCDS cable and a few minutes, it is simply a case of following these steps and you should be good to go.
    It's worth noting that my car is a UK car, running Firmware P2711.
    Open VCDS
    5F
    Adaption
    Long coding
    Vehicle config
    * Mirror link ON
    * Wi-Fi client HMI ON
    * WLAN 5ghz switch ACTIVATE
    * Apple DIO wireless ACTIVATE
    Once I'd made these changes, I made my phone 'forget' the car in Bluetooth settings, and re-paired it. A quick reset of the MMI (pressing the volume button in for 15 seconds), and hey presto.
    After that, Apple CarPlay comes up on the main menu, rather than 'Phone Apps'.
    I hope this helps someone. I'm absolutely not an expert at this, but it's worked for me.
    0 2 0
  2. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    6 Post(s)
    Did you got some errors from 5F after this operation ? (like uncorrect SW version?)
    Thank you,
    Enrico
  3. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    Feb 2017
    Lincoln, UK
    Quote Originally Posted by enry68 View Post
    Thank you,
    Enrico
    Nothing at all, Enrico.
    I made sure to restart the MMI by holding the volume knob in until the system restarted, then re-paired my phone. It asked me if I’d like to use CarPlay, and everything has worked fine since.
  4. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    6 Post(s)
    Thanks for the answer.
    Same for me but I have now an error on the 5F module: Incorrect SW Version. I don't understand why.
  5. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    Aberdeen
    63 Post(s)
    Hope you don't mind but I have made this a sticky. We need a sticky for software / VCDS changes for the C8 albeit limited in what is possible so far!
  6. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    131 Post(s)
    1973 Post(s)
    Maybe we should edit the title just in case someone thinks this is a time travel thread.
    0 2 0
  7. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    6 Post(s)
    About the SW problem.... It seems that after an upgrade FW or maps(to be verified for this) it's necessary to change a code in a particular channel of the adaptation of the 5F. I've changed this code by a simple calculation and the error has been cleared.
  8. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    Feb 2017
    Lincoln, UK
    Glad you got this sorted! Was it a simple change?
  9. Re: Activating wireless Apple CarPlay 2029 A6 Avant
    6 Post(s)
    Yes, it's very simple. Here the complete explanation: Fix SVM code B201A - Checking software version management - YouTube
    I hope it can help you.
    Enrico
  1. Wireless carplay
    By Robbs3 in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 16-04-2020, 01:22 PM
  2. Wireless CarPlay Issues
    By Big_D_80 in forum Q7 - 4M Forum - 2016 -
    Last Post: 04-02-2020, 10:53 PM
  3. Wireless carplay
    By nbedford in forum Q7 - 4M Forum - 2016 -
    Last Post: 21-01-2020, 09:13 PM
  4. Wireless Apple CarPlay AND Wireless Charging
    By minieggs in forum In Car Entertainment
    Last Post: 21-08-2019, 02:17 PM
  5. Apple carplay installed on non Audi registered Carplay cars
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 03-05-2019, 06:44 AM
