Thread: B7 convertible drivers window not closing correctly
Results 1 to 1 of 1
  1. B7 convertible drivers window not closing correctly
    Jan 2022
    Haywards Heath UK
    Solved : Hi newbie here, 2007 A4 convertible, I have just fitted a new drivers window regulator today, the window seems to be lifting to the correct height but it's then not going back the 5mm to fully meet the rubber strip of the back window like it is meant to does it need adjusting to overcome this 5mm gap that I now have? Before it used to lift the window to correct height then shunt it back.
    The fault was that the wire in the regulator had snapped.
  1. 2010 A6 Avant drivers side rear window not fully closing
    By jones_g in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-02-2021, 11:19 PM
  2. Passenger side window not working correctly
    By buddyboy in forum A7 - S7
    Last Post: 24-05-2017, 03:58 PM
  3. Convertible roof not closing at final stage
    By thetruth in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-03-2016, 02:47 PM
  4. Drivers Window Slow closing
    By supersiecosse in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-03-2015, 01:03 AM
  5. Snapping/Cracking Noise when closing drivers door
    By tdci115 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-03-2012, 11:29 AM
