Thread: Coolant valve for cylinder head
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Coolant valve for cylinder head
    #11
    Jan 2022
    oldham
    That's great crasher I'll do that. Thank you so much
    Sent from my SM-G991B using Tapatalk
  2. Re: Coolant valve for cylinder head
    #12
    Mar 2013
    Reading
    31 Post(s)
    Quote Originally Posted by scottieH View Post
    Hi.
    I have an a6 avant 3.0 diesel 245ps.It is the CDUD engine. I have had the following code from vcds. 10382-coolant valve for cylinder head, P199E 00(047) open circuit. I am struggling to find what it is and where it is on the engine so I can check it and replace if necessary. Could anyone help me? I have asked on the vcds and been told it is a concern with the N489 cylinder head coolant valve which is located on the left front side of the engine. I cannot find any info or pictures of this item and even contacting my local audi, they don't know what this valve is. I am a bit stuck!!!!!!!!
    Thanks in advance
    Hey Scotty, have you resolved this?
    I had mine complaining for some time now and this morning, it added "Intake Manifold Runner Control Bank 1 stuck closed". It might or might not be connected but it's time to resolve it all.
    ta
  3. Re: Coolant valve for cylinder head
    #13
    120 Post(s)
    1897 Post(s)
    We had that on an A4 2L TDI a few months back and even a new genuine manifold would not cure it, the problem was the ECU.
  4. Re: Coolant valve for cylinder head
    #14
    Mar 2013
    Reading
    31 Post(s)
    :/ hope I don't end up in that bucket...
    Sent from my KB2003 using Tapatalk
  5. Re: Coolant valve for cylinder head
    #15
    Jan 2022
    oldham
    Hi Johnny31. I ended up changing the valve which sits on top of the engine, although my problems went a little deeper, with an RAC man poured cold water into my overheated engine which caused cylinder head gasket failure! Ended up with another engine, new turbo and new egr cooler. Had to get a mortgage for it!!
  6. Re: Coolant valve for cylinder head
    #16
    Mar 2013
    Reading
    31 Post(s)
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Replies: 1
    Last Post: 15-12-2021, 09:06 PM
  3. Replies: 28
    Last Post: 30-10-2009, 02:12 AM
  4. Replies: 0
    Last Post: 27-11-2007, 01:12 AM
  5. cylinder head
    By benno020388 in forum Bora - 1998 - 2005
    Last Post: 19-09-2007, 07:55 PM
