Thread: Coolant valve for cylinder head
Results 1 to 10 of 16
  1. Coolant valve for cylinder head
    Jan 2022
    oldham
    Hi.
    I have an a6 avant 3.0 diesel 245ps.It is the CDUD engine. I have had the following code from vcds. 10382-coolant valve for cylinder head, P199E 00(047) open circuit. I am struggling to find what it is and where it is on the engine so I can check it and replace if necessary. Could anyone help me? I have asked on the vcds and been told it is a concern with the N489 cylinder head coolant valve which is located on the left front side of the engine. I cannot find any info or pictures of this item and even contacting my local audi, they don't know what this valve is. I am a bit stuck!!!!!!!!
    Thanks in advance
  2. Re: Coolant valve for cylinder head
    135 Post(s)
    2040 Post(s)
    Message me the reg or post the VIN
  3. Re: Coolant valve for cylinder head
    Mar 2010
    Derry ireland
    68 Post(s)
    The cylinder head cooling solenoid on your engine code cdud is a 2 terminal solenoid which when checked across its 2 pins the ohms reading should be 10-15 ohms must have a 12v feed at terminal 1 & is earthed at ecu pin no b39
  4. Re: Coolant valve for cylinder head
    Jan 2022
    oldham
    Hi crasher. The Reg is MFZ3079
    Sent from my SM-G991B using Tapatalk
  5. Re: Coolant valve for cylinder head
    Jan 2022
    oldham
    Thanks mickybo. Just need to find the little b#@ger
  6. Re: Coolant valve for cylinder head
    Jan 2022
    oldham
    Has anyone got a photo of the coolant valve and its location?
  7. Re: Coolant valve for cylinder head
    Jan 2022
    oldham
    Or even a part number?
  8. Re: Coolant valve for cylinder head
    135 Post(s)
    2040 Post(s)
    10382 - Thermostat for Cylinder Head P199E 00 [039] - Open Circuit
    Was 059 121 737 H, now 059 121 737 AM and £75.41 retail inc VAT genuine but that is vacuum operated
  9. Re: Coolant valve for cylinder head
    Jan 2022
    oldham
    Thanks crasher. Would it cause any issues to fit a vacuum unit instead?
  10. Re: Coolant valve for cylinder head
    135 Post(s)
    2040 Post(s)
    It must be referring to the solenoid for operating the valve, we have done a lot of these valves because they leak, and yes this is called N489 which is on the wiring diagram but does not come up in the workshop information and in ETKA (under that code which is known as an SDC) it points as varies valves but is shown in the wiring diagram as being ECU earth controlled and power feed by the same supply as a few other components such as the electro hydraulic engine mounts, so if the power supply was bad you would expect matching codes. This means the solenoid is in the multi valve that controls the EGR as well. I THINK it is item 41 on page 131-013 part number 1K0 906 283 A... but it could be item 45, 059 906 627 L (now 059 906 627 R), FI suggestion to your VIN indicates both... as well as various temperature sensors. I would follow the vacuum line back and find the solenoid and get the part number off it.
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Replies: 1
    Last Post: 15-12-2021, 09:06 PM
  3. Replies: 28
    Last Post: 30-10-2009, 02:12 AM
  4. Replies: 0
    Last Post: 27-11-2007, 01:12 AM
  5. cylinder head
    By benno020388 in forum Bora - 1998 - 2005
    Last Post: 19-09-2007, 07:55 PM
